rzusman
ENC28J60 SPI Ethernet INT remap
Thu Mar 31, 2016 4:47 am
I'd like to add this Ethernet module to my Compute Module (I'm currently using a USB-Ethernet adapter, but I'd like to free up the USB port. Ethernet speed is not critical). The configuration instructions seem straightforward, but they call for using GPIO 25 as the interrupt input, and I'm currently using it for something else.
Is there a simple way to tell the driver to use a different GPIO?
I understand that the device tree can be edited, but I've never done that, and am clueless about how to proceed.
DirkS
Re: ENC28J60 SPI Ethernet INT remap
Thu Mar 31, 2016 11:01 am
You can use the device tree parameter 'int_pin'
See https://github.com/raspberrypi/firmware ... t/overlays or /boot/overlays/README on your CM
Example:
dtoverlay=enc28j60,int_pin=99
rzusman
Thu Mar 31, 2016 5:52 pm
Thank you, that worked perfectly.
jpotpo
Wed Apr 06, 2016 12:06 pm
does anyone have a overlay for Asix AX8879c ethernet controller ?
6by9
Wed Apr 06, 2016 12:57 pm
jpotpo wrote:does anyone have a overlay for Asix AX8879c ethernet controller ?
Have you got the right part number there? Did you mean AX88796 ? Your other post would imply so.
Seeing as CONFIG_AX88796 isn't defined in the default kernel build, I doubt anyone will have set up an overlay, but at least there is a driver available (https://github.com/raspberrypi/linux/bl ... /ax88796.c).
Seeing as that driver is missing any device tree config, you'll have to make changes to it along similar lines to the changes for enc28j60. No DT support in the driver precludes anyone having done a DT overlay for it!
jpotpo
Wed Apr 06, 2016 6:49 pm
yes that is the chip and thanks for the info
shawaj
Thu Jul 14, 2016 12:01 pm
does the int pin actually need to be connected?
Support The MagPi by purchasing printed copies from one of our retailers - http://themagpi.com/en/buy
Please share with anyone who is interested!
Fri Jul 15, 2016 5:08 pm
shawaj wrote:does the int pin actually need to be connected?
Yes unless you like dropped packets and re-transmits.
Return to “Compute Module”
