ashcharles
Connecting external SD/SDIO device
Fri Oct 02, 2015 7:32 pm
I'm trying to hook up a Wifi chip via SDIO to the SD1 interface (GPIO22-27, ALT3) on the compute module. I've enabled the sdio-overlay and see linux attempt to initialize mmc1 but it fails repeating this message several times:
[ 2.283907] mmc1: host does not support reading read-only switch, assuming write-enable
[ 2.300090] mmc1: error -110 whilst initialising SD card
I tried compiling both a stable rpi-4.1.y kernel as well the most recent rpi-4.2.y branch with no noticeable difference in behaviour. I see reasonably clean signals @ 3.3V on the interface and, with a logic analyser, I can see what looks like a good MMC initialization sequence (CLK@400kHz, CMD signalling, and, eventually activity on DAT1). To rule out hardware initialization problems with the Wifi chip, I also tried wiring up a microSD card but with no success.
1. What might I be missing here? Should I be able to use this interface for SD (not SD via SPI)? These posts [1, 2] hinted to me that this should be possible so I'm probably doing something silly.
2. Does this SD interface support the 1.8V signalling mode?
Many thanks for any insights.
[1] viewtopic.php?f=98&t=74487
[2] viewtopic.php?f=98&t=88781
(My first post! Please excuse me if this is not the right forum for this question.)
ashcharles
Re: Connecting external SD/SDIO device
Mon Oct 05, 2015 3:31 pm
To follow up, I tried hooking up the microSD card to an RPI 2 B rather than to the Compute Module as described. It started up without error: linux happily recognized and initialized a /dev/mmcblk1 device. Hmm...processor specific difference?
gsh
Wed Oct 07, 2015 6:02 am
Did you set up the alternate settings for the GPIO as well? You should be able to do this using the device-tree
Can you actually see the signals on the bus with a scope?
Gordon
Gordon Hollingworth PhD
ashcharles
Wed Oct 07, 2015 3:44 pm
Thanks for the response :).
I added dtoverlay=sdio [1] to my config.txt which remuxes the sdio pins "brcm,function = <7 7 7 7 7 7>; /* ALT3 = SD1 */" as well as pulling in the sdhost overlay [2] which ensures the eMMC pins are muxed. Is there additional muxing or pin configuration needed?
I'm able to see the SD initialization sequence with a scope i.e 400kHz clock and toggling on the CMD line before I get the 'timed out' message from Linux.
[1] https://github.com/raspberrypi/linux/bl ... verlay.dts
[2] https://github.com/raspberrypi/linux/bl ... verlay.dts
oneinsect
Wed Dec 02, 2015 4:17 am
Hi charles,
Were you able to connect any sd card via SDIO pins?
ashcharles
Fri Dec 04, 2015 1:19 am
Hi oneinsect,
IIRC, I was only successful hooking a microSD card up to an RPI B-2, not the Compute Module. Unfortunately, I don't remember exactly how I hooked it up but I suspect, based on the "brcm,pins = <22 23 24 25 26 27>;" from the overlay, that I tried these GPIOs.
Ash
oneinsect
Fri Dec 04, 2015 2:08 am
Thanks charles
Anyone can please tell how those pins are mapped to an sd card?
vjvarada
Wed Mar 30, 2016 5:14 pm
Hi!
Any luck on the Compute module? im facing the exact same issues as you are, Charles.
ashcharles
Wed Mar 30, 2016 5:16 pm
Sorry---no luck. I've had to move on to other challenges. Certainly post back though if you uncover anything interesting.
Return to “Compute Module”
