chenbm4
Raspberry Pi Compute Module Reformat
Wed May 20, 2015 3:49 am
My compute module is not able to get past early in the boot stage. I believe I may have corrupted the disk image in the file transfer, and I would like to redo everything. How do I erase everything I did and start from scratch?
MarkHaysHarris777
Re: Raspberry Pi Compute Module Reformat
Wed May 20, 2015 5:12 am
chenbm4 wrote:Hi,
Why are you not able to grab the latest Raspbian image, your development board, and your micro usb cable, and then reflash the eMMC from your host PC?
marcus
:ugeek:
BobKruse
Thu May 21, 2015 6:41 pm
I just received my compute module this week
I've spent a full day trying to get the latest Raspbian image to boot up.
I got 2015-02-16-raspbian-wheezy.zip from https://www.raspberrypi.org/downloads/, followed directions and copied it over from my rpi2. No luck.
I found this link viewtopic.php?f=98&t=105386 which suggested I try an older image.
and I found 2014-12-24-wheezy-raspbian.zip at http://downloads.raspberrypi.org/raspbi ... 014-12-25/
This one just worked.
I hope this helps,
Bob
Return to “Compute Module”
