HardTech
Breakout board
Wed Apr 29, 2015 10:39 pm
Is there a small break out board for the compute module. The break out board only needs to gain access to the pins on the CM
Briarios
Re: Breakout board
Thu Apr 30, 2015 1:43 am
The Only breakout board that I know of that will give you access to the pins is the devboard that comes with the Compute module.
http://rpi.pmfg.me -- Test board Eagle Cad Files.
Re: Breakout board
Thu Apr 30, 2015 7:32 am
MarkHaysHarris777
Re: Breakout board
Thu Apr 30, 2015 7:51 am
Be cautious of the compute module. Broadcom has an agreement with the Raspberry PI foundation, but may not deal directly in limited quantities to individuals, kickstarts, or small enterprises. You may need to order a couple of thousand modules ! Availability might be tight. This has happened before, it will happen again; you've been warned.
On the other hand, the breakout board Dougie listed above is *very* tempting isn't it?
marcus
:ugeek:
stuartclark
Re: Breakout board
Thu Apr 30, 2015 7:59 am
MarkHaysHarris777 wrote:Be cautious of the compute module. Broadcom has an agreement with the Raspberry PI foundation, but may not deal directly in limited quantities to individuals, kickstarts, or small enterprises. You may need to order a couple of thousand modules ! Availability might be tight. This has happened before, it will happen again; you've been warned.
I'm not sure I understand what you mean?
Broadcom doesn't make the compute module, the RPI foundation do, so there is no need to deal with Broadcom directly at all (indeed as you say they would have very large minimum orders and you wouldn't have access to everything you needed anyway, such as the closed source firmware code made by the RPI foundation).
RaTTuS
Contact: Twitter YouTube
Re: Breakout board
Thu Apr 30, 2015 8:14 am
dunno what you are thinking of ...
the CM is nothing really to do with broadcom
farnell / rs sell them
http://cpc.farnell.com/raspberry-pi/rpi ... dp/SC13437
http://uk.rs-online.com/web/p/processor ... s/8268825/
and the dev kit on RS is a lot cheaper now
http://uk.rs-online.com/web/p/processor ... s/8134164/
Covfefe
MarkHaysHarris777
Re: Breakout board
Thu Apr 30, 2015 8:34 am
RaTTuS wrote: dunno what you are thinking of ...
hi, do you know whether the CM can be purchased without limits (and) does farnell have an agreement with broadcom ? I have been warned in the States that the CM would not be a practical development opportunity because of availability and pricing (or outrageous quantities) that change once the prototype goes into production... is this possible, or just hype?
thanks
marcus
:ugeek:
rpdom
Re: Breakout board
Thu Apr 30, 2015 8:38 am
MarkHaysHarris777 wrote:hi, do you know whether the CM can be purchased without limits
You'd have to talk to Farnell (or RS?) about quantities. Are you talking thousands or tens/hundreds of thousands?
Well, yes. Otherwise they wouldn't be able to make the Pi. ;)
ghans
Re: Breakout board
Thu Apr 30, 2015 8:43 am
Both Farnell and RS would propably like huge orders (actually , i think it was the Pi which forced
them to learn how to deal with hordes of private , individual customers for the first time).
But since the CM is meant to be integrated into your own products customers seem to take their time to fine-tune everything.
I think you should clearly communicate with Farnell/RS via their official sales contacts how much you need.
This forum is propably not the right place to negotiate huge orders (not to forget that not all Foundation and
almost zero RS / Farnell representatives watch it hour after hour) .
ghans
stuartclark
Re: Breakout board
Thu Apr 30, 2015 8:46 am
thanks
Warned by whom?
Someone from RPI should be able to give you whatever guarantees you need relating to how long it will be available & quantities, but they haven't indicated any limits so far (excepting any stock issues due to demand at times, which should be quickly fixed) and have indicated CM will be available for "years".
RaTTuS
Re: Breakout board
Thu Apr 30, 2015 10:15 am
I cannot answer for farnell or rs or mcm or elemet14 etc
but you can easily buy 1 - 1000 from them if you are wanting 10's or 100's of thousands then contacting them directly will give you a price point and delivery scheduled
I know rs uk has approx 8k for immediate delivery
Covfefe
gsh
Re: Breakout board
Tue May 19, 2015 11:09 am
There is no limit to the availability of the Compute Module, if you want 1m devices then RS and Farnell will be able to supply them, if you're actually interested in that sort of quantity then they'll talk to you directly, if you're just interested in a couple of thousand then they have those sitting waiting
As for 'warned' that sounds like you were warned by a party interested in selling you a $1000 embedded PC instead!
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
Return to “Compute Module”
