rmvmotion
CM4 TWO Ethernet Port
Sun Jul 18, 2021 6:42 pm
We need to use CM4 with two Ethernet ports to support different automation protocols.
Is any application samples or suggestions to incorporate two Ethernet ports.
I wonder how I get more detail on the processor BCM2711 in peripherals description Ethernet Interface was omitted .
Albert
pasman1
Re: CM4 TWO Ethernet Port
Sun Jul 18, 2021 6:47 pm
Pi4 RaspbOS 64+LXQT, linux 5.10.52-v8
Sun Jul 18, 2021 6:48 pm
The Bcm2711 only has one set of ethernet port hardware,so you would need to add another port via, probably, USB.
Working in the Applications Team.
Gavinmc42
Mon Jul 19, 2021 7:06 am
SPI and PCI too.
https://www.microchip.com/en-us/product ... ontrollers
What speed Ethernet?
I'm dancing on Rainbows.
rmvmotion
Sun Jul 25, 2021 6:19 pm
Thank you very much to all for the answers.
Albert
rmvmotion
Sun Jul 25, 2021 6:38 pm
In regards to the Speed we Need 1Gb Ethernet, Seems we sould implement via PCIe to get this speed ,
Do you recommend a controller that will be inetrface via PCIe >
Albert
Sun Jul 25, 2021 8:09 pm
I'm asking around to see if there is such a thing as a dual ethernet PCIe chip. Apparently there is, but I don't know any part numbers. Can also get more ports.
However, I suspect that even if you find such a device, getting hold of them in quantity is unlikely given the current chip shortages, some stuff is currently on 52wk lead times.
Edit: Something like this, you'll need to find out what chipset is on it. https://www.amazon.co.uk/StarTech-com-4 ... th=1&psc=1
davidcoton
Sun Jul 25, 2021 8:35 pm
HIGH BANDWIDTH CONNECTIVITY: The dual port NIC card features a high-performance Intel i350 chipset that supports link aggregation / teaming support, enabling you to add additional bandwidth to your system
(My emphasis)
trejan
Sun Jul 25, 2021 8:40 pm
Do you need 2x gigabit Ethernet in addition to the one that is on the CM4? If not then single PCIe ethernet + onboard CM4 ethernet would do it.
Do you need the full gigabit throughput on both interfaces concurrently? Would using the CM4 ethernet as a trunk to an onboard switch chip with VLANs work?
6by9
Mon Jul 26, 2021 7:31 am
Devices tested on a CM4 - https://pipci.jeffgeerling.com/#network ... i-adapters
Intel I340-T4 PCIe x4 4-port Gigabit Network Adapter has been shown to work. As above, whether you can buy the raw chips is a different question.
Return to “Compute Module”
