mcnpower
CM4 Passive Cooling
Mon Jul 19, 2021 11:48 am
There are many aluminum heatsinks made specifically for the CM4. Some of these are only contacted with the heatsink by placing a thermal pad on the processor. Some have also placed thermal pads on parts such as eMMC and Ram and come into contact with the heatsink.
Which of these is correct? eMMC, RAM, Wifi Module getting hot? If it does not heat up, do we put them in contact with the heatsink along with the processor and cause them to heat up? Or the more contact we make with the heatsink, is it good for the CM4?
Some examples heatsink for CM4:
https://www.waveshare.com/cm4-heatsink.htm
https://www.amazon.com/dp/B092PMY7RC/re ... WYVZQ9VFPN?
https://www.amazon.com/Geekworm-Aluminu ... B08PZ39L46
aBUGSworstnightmare
Re: CM4 Passive Cooling
Mon Jul 19, 2021 12:36 pm
My clear recommemdation is the Geekworm cooler viewtopic.php?f=98&t=298810
It uses TIM for the SOC and the RAM and allows for concection on the rest of the boards components.
It's quite often not the PMIC which gets hot, it are the coils. So, where to start with other components and wherento stop?
Edit: btw .. Stacking two pieces of TIM on top of each other is not the best idea.
mcnpower
Wed Jul 21, 2021 8:23 pm
Thanks for the answer.
First thing I will do a stress test on CM4 and monitor it with a thermal camera.
I plan to see which parts are getting hot.
I'll post the results here.
aBUGSworstnightmare
Thu Jul 22, 2021 6:41 am
or simply look at available results https://www.jeffgeerling.com/blog/2020/ ... e-module-4
As you can see it's the SoC and the RAM which get's hot
image by Jeff Geerling from the blog linked above
Return to “Compute Module”
