DeBuffel
RPi CM4 IO board - Looking for DIN case
Tue Jun 15, 2021 3:29 pm
Hello all,
I am looking for a din case in which the RPi CM4 IO board fits (https://datasheets.raspberrypi.org/cm4i ... asheet.pdf)
Did search Google and surprisingly I was not able to find one :-(.
So I hope that you can help me finding this din case as I am pretty sure they are out there.
Thanks in advance,
DeBuffel
aBUGSworstnightmare
Re: RPi CM4 IO board - Looking for DIN case
Tue Jun 15, 2021 7:23 pm
So far there is none (at least I haven't seen one yet)
Get this https://www.waveshare.com/cm4-io-board-case-a.htm and add rhe rail mount of your choice.
DeBuffel
Wed Jun 16, 2021 8:11 am
Thanks, that helps me to get started.
It is a petty is that the PCB of the CM4 IO board is dimensioned as 900(mm) x 1600(mm).
The DIN case I found have a width of 89.8(mm)... grrr
The metal case as you posted sounds like a good alternative. Now I need to see where to get a rail mount which is easily to place at the back of the metal case. Suggestions are welcome :-)
Wed Jun 16, 2021 9:43 am
I've got a thing called a Sourcekit Pitray clip on my desk, which is a stainless bracket for the Pi with a DIN rail connector.
Trying to find it on the net....it might be a new product that hasn't been advertised yet.
Working in the Application's Team.
aBUGSworstnightmare
Wed Jun 16, 2021 9:45 am
well, using google seems to be an issue sometimes, so if I were you I would google for 'DIN rail mount kit' which brings up stuff like
don't ask me how to make holes in the metal chassis...
DeBuffel
Wed Jun 16, 2021 9:53 am
Thanks - also found some :-)
https://www.reichelt.nl/nl/nl/din-rail- ... 9.html?r=1
Will order them and drill some holes :shock:
aBUGSworstnightmare
Wed Jun 16, 2021 10:16 am
good find! Looks like a lower profile and one should be sufficient for the case anyhow. Issue might become removing it from the rail as I don't see how this one locks. As it will be hidden behind the CM4IO case you may have to develop some innovative idea..
DeBuffel
Wed Jun 16, 2021 4:45 pm
It looks like a spring. So push it upwards and pull out bottom (or visa versa). I will expreience once I receive them
Return to “Compute Module”
