meloon
CM4 ETH pairs swap
Tue May 18, 2021 12:19 pm
I maked custom board based on RPi CM4. ETH connector is on top of PCB and SOM is on bottom side, so I decided to swap pairs to make track routing easier . BCM54210 datasheet is not available, but CM4 datasheet specified that PHY can detect pair swap and line swap. First prototype have ETH pairs swapped as follows:
CM4 - RJ45 socket
TRD0 - TRD2
TRD1 - TRD3
TRD2 - TRD0
TRD3 - TRD1
Ethernet doesn't work on straight cable, but when I swapped pairs in RJ45 jack to reverse changes on PCB it works fine.
Is there any limitation regarding to pair swap or maybe I made something wrong? What about polarity swap in single pair?
dp11
Re: CM4 ETH pairs swap
Tue May 18, 2021 5:24 pm
I've had a quick go in the lab swapping pairs over in a cable ( not quite the same as on the PCB) and it appears to work. e.g orange to green and brown to blue.
LakshmiN
Wed May 19, 2021 10:05 am
I've also had a similar issue where,
CM4 RJ45 jack
TRD0 TRD0
TRD1 TRD1
TRD2 TRD3
TRD3 TRD2.
I should expect it to work.
but Ethernet doesn't work on straight cable
Return to “Compute Module”
