iocapa
Repurposing "Camera_GPIO" pin
Tue May 11, 2021 3:53 pm
Hello. I'm using the CM4 in an application that requires setting the GPIO_VREF to 1.8V.
However, I need one extra 3.3V referenced GPIO (other than 44/45), without adding any extra voltage dividers.
For this i was looking at 97 (Camera_GPIO), since I do not use the camera, and use it as an input to signal some interrupt coming from an external device.
However, I couldn't find any documentation on how to reassign this pin, or even if it's possible.
The datasheet says:
"Reassigning this pin to another function isn’t recommended."
This sounds like not recommended, but possible ;)
Any thoughts on that?
Regards
dp11
Re: Repurposing "Camera_GPIO" pin
Wed May 12, 2021 8:18 am
You will need to read and understand the device tree structure which describes the CAM_GPIO pin.
6by9
Wed May 12, 2021 10:05 am
You can do it, but do NOT configure a dt-blob.bin such that the firmware knows about the camera, otherwise the firmware will start changing the state on you.
It is via an I2C GPIO expander controlled by the firmware, so goes via raspberrypi-exp-gpio driver.
As defined in DT for the camera regulator, it's GPIO 5 on that expander.
iocapa
Wed May 12, 2021 1:51 pm
Ok. Thanks everyone.
I was not aware that it's via an expander.
Guess I'll go with a simple voltage divider and route it to a standard 1V8 GPIO.
I don't want to risk the extra overhead since the details of the subsystem using
that line are not yet fully defined (will signal an interrupt after which a custom driver will read/write something through I2C GPIO44/45).
Regards
6by9
Wed May 12, 2021 2:12 pm
FWIW raspberrypi-exp-gpio doesn't support interrupts.
Return to “Compute Module”
