andrum99
[SOLVED] (No) Potential to brick a CM4
Mon Apr 19, 2021 7:15 pm
I believe I may have spotted a potential hole which would allow a developer to inadvertently brick their CM4. The documentation at https://www.raspberrypi.org/documentati ... lashing.md says that CM4 never runs recovery.bin from SD/eMMC, which is the method for recovering the Pi 4 from an invalid EEPROM image. Absent some other way of running recovery.bin, this means that if, for example, there is a power cut while the CM4 bootloader EEPROM is being updated, then the CM4 could end up being bricked. I'm assuming this is not actually the case though, so what is the method for running recovery.bin on the CM4?
PhilE
Re: Potential to brick a CM4
Mon Apr 19, 2021 7:22 pm
cleverca22
Mon Apr 19, 2021 7:35 pm
ive asked the same question before, and got the answer that recovery.bin is disabled on a CM4
https://github.com/librerpi/rpi-open-fi ... xt#L88-L93
according to my notes, bits 11-13 of OTP17 control which pins the sd/eMMC have to be on, for recovery.bin loading to work
a value of 0 in those 3 bits, will disable recovery.bin loading
pi@pi400:~ $ vcgencmd otp_dump | grep 17:
17:000008b0
clever@c2d ~ $ node
> (0x000008b0 >> 11) & 7
1
on my pi400, it is enabled, as expected
i havent gotten an eMMC CM4 yet, to verify if this is how it got disabled
andrum99
Mon Apr 19, 2021 9:19 pm
That page does not specify a method to run recovery.bin on CM4. It does say that recovery.bin not running on the CM4 can be overridden, but it does not specify a way of doing this. Can you possibly explain how to run recovery.bin on CM4? My reason for asking is that it would seem to be a useful thing to add to the documentation, which I intend to do.
PhilE
Mon Apr 19, 2021 9:24 pm
You use rpiboot/usbboot:
Flashing the bootloader EEPROM - Compute Module 4
To flash the bootloader EEPROM follow the same hardware setup as for flashing the EMMC but also ensure EEPROM_nWP is NOT pulled low. Once complete EEPROM_nWP may be pulled low again.
# Writes recovery/pieeprom.bin to the bootloader EEPROM.
./rpiboot -d recovery
cleverca22
Tue Apr 20, 2021 4:24 am
to explain it a bit further
loading of recovery.bin from the eMMC is disabled
when you close the nRPI_BOOT jumper, then loading of bootcode.bin from SPI flash will also fail
the rom's only remaining option is rpiboot/usbboot
you can then push a copy of recovery.bin over usb, using the rpiboot protocol (but its been renamed to bootcode4.bin, to keep you on your toes)
it will detect that your using it in rpiboot mode, and request the poeeprom.bin + pieeprom.sig over the rpiboot protocol, and re-flash things
timg236
Tue Apr 20, 2021 9:44 am
Pulling nRPIBOOT low instructs the ROM to skip all other boot modes and enter a loop waiting for the usbboot/rpiboot.
You can't brick this by erasing the EEPROM contents, in fact manufacturing test relies upon this working because the EEPROM starts out as a blank image.
Documented here https://www.raspberrypi.org/documentati ... ow_2711.md
andrum99
Tue Apr 20, 2021 4:15 pm
Thank you for explaining this - that's the bit I was missing.
Not quite - it doesn't mention anything about the ROM skipping all other boot modes and waiting for usbboot/rpiboot - it makes no mention of what happens if nRPIBOOT is enabled and asserted. I'm assuming if nRPIBOOT is enabled and asserted then the ROM does not attempt to run the bootloader EEPROM?
cleverca22
Re: [SOLVED] (No) Potential to brick a CM4
Tue Apr 20, 2021 5:38 pm
i cant find the schematic to back up my claim, but i remember seeing that nRPIBOOT is just wired to one of the spi data lines
so pulling it low isnt asking the rom to skip SPI, its forcing SPI access to fail
but the rom does have support to let any gpio pin temporarily skip SPI loading, so doing it better is an option
i just cant be sure which way the CM4 is doing it, and the schematics are missing from the old documentation repo on github
timg236
Wed Apr 21, 2021 4:53 pm
It doesn't force SPI accesses to fail. If it did, it would be impossible to use recovery.bin with nRPIBOOT pulled low to update the bootloader EEPROM.
Return to “Compute Module”
