Hello everyone,
I'm currently designing a custom carrier board for the Compute Module 3+. I intend to have at least one (possibly two) CSI ports on the board, but I'm confused about the connectors. I can see in the documentation that both the Pi Zero and Compute Module IO board use a 22-pin connector which has 3 extra ground pins and 4 NC pins compared to the 15-pin connector used in other versions of the Pi.
So from what I understand, electrically there's no difference between the two connectors (correct me if I'm wrong). Is it possible to design the custom board with the 15-pin connector, to avoid having to use an adapter/special cable? If so, what is the reason that the Pi Zero and CMIO board are designed with the 22-pin connector?
