rlev
eMMC Backup
Sun Jan 19, 2020 3:17 am
How to backup a Compute Module 3 Plus eMMC to a .img file in an external USB stick to be reuse in other CM3 modules for production?
Is this possible?
rlev
Re: eMMC Backup
Sat Jan 25, 2020 2:39 am
Anyone?
PhilE
Re: eMMC Backup
Sat Jan 25, 2020 11:22 am
Use dd? Something like:
$ sudo dd if=/dev/whatever of=backup.img bs=128k
rlev
Re: eMMC Backup
Mon Jan 27, 2020 1:46 pm
Thanks PhilE
Will try that.
PhilE
Re: eMMC Backup
Mon Jan 27, 2020 2:11 pm
The "<whatever>" is likely to be "/dev/mmblk0" for the whole EMMC.
wariswala
Re: eMMC Backup
Fri Feb 14, 2020 11:39 am
Is this possible?
There are a few ways of making a backup of your EMMC/SD card. The simplest to implement is to make a 1:1 binary copy of your data to an image file. For this task you can use a tool such as dd or Win32diskImager. Note that all the commands that follow expect to have the variable $backupDir replaced by the path to your desired backup directory (which can't be on the same partition you're trying to backup for obvious reasons).
CODE: SELECT ALL
$ sudo dd if=/dev/mmcblk0 of=$backupDir/backup.img bs=1M
Return to “Compute Module”
