wmthesecond
Measuring Current Draw on Specific Pins
Fri Oct 05, 2018 3:11 pm
I am looking to measure the current draw of specific pins (VDAC, 3V3, 1V8, VBAT) on the Raspberry Pi Compute Module 3, but am not sure how to go about doing it. I have considered soldering leads to the pins but am not sure this is feasible given their size. Any advice?
aBUGSworstnightmare
Re: Measuring Current Draw on Specific Pins
Fri Oct 05, 2018 6:16 pm
The CMIO has four Zero (0) Ohm resistor: R1,R4,R5,R6
You can unsolder them and measure current from there.
Refer to page 2 of the CMIO schematic https://www.raspberrypi.org/documentati ... IO_3p0.pdf
smaddox
Sat Nov 09, 2019 3:11 pm
Hi wmthesecond,
Did you measure draw for these or did you find the information elsewhere? Am working on a CM3 based PCB and have the RPi stated draw, which I presume is the "absolute maximum", and would like to understand what minimum and typical are.
thx - sean
Return to “Compute Module”
