rgk
Adding WiFi/Ethernet to the Compute Module 3+
Mon Jul 22, 2019 2:16 pm
To use a compute module 3+ in an industrial setting it is highly likely that one would want to add the very same WiFi/Ethernet that is on the Raspberry Pi 3B+. Is it possible for raspberrypi.org to post that portion of the RPi 3B+ schematics to the compute module documentation page with any code requirements? The SPI version suggested on the documentation page at https://www.raspberrypi.org/documentati ... w-guide.md would be inadequate for most industrial uses.
Return to “Compute Module”
