GO-IOT
Kernel Crash with GSM Modem AND I2C-0 Enabled
Tue Nov 28, 2017 4:45 pm
We are using the Raspberry Compute Modules 1 & 3
Linux Version
Linux DINgo 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
SHA-256: bd2c04b94154c9804cc1f3069d15e984c927b750056dd86b9d86a0ad4be97f12
We only see the following problem with Compute Module 3 and NOT Compute Module 1
The USB Architecture is as follows:-
The Raspberry PI USB is connected to a GL852G - 4 port Multi TT USB Hub
Port 1 of the GL852G connects to a LAN9512 - Ethernet Controller and External USB Ports 1 & 2
Port 2 of the GL852G connects to a CP2108 - Quad USB to Serial Converter - ttyUSB0 - ttyUSB3
Port 3 of the GL852G connects to an internal USB Port 1 (various USB peripherals)
Port 4 of the GL852G connects to an internal USB Port 2 (various USB peripherals)
lsusb -t
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
            |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
        |__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=cp210x, 12M
        |__ Port 2: Dev 4, If 3, Class=Vendor Specific Class, Driver=cp210x, 12M
        |__ Port 2: Dev 4, If 1, Class=Vendor Specific Class, Driver=cp210x, 12M
        |__ Port 2: Dev 4, If 2, Class=Vendor Specific Class, Driver=cp210x, 12M
lsusb -v
lsusb -v
Bus 001 Device 004: ID 10c4:ea71 Cygnal Integrated Products, Inc.
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x10c4 Cygnal Integrated Products, Inc.
  idProduct          0xea71
  bcdDevice            1.70
  iManufacturer           1
  iProduct                2
  iSerial                 7
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          101
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              3
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              4
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              5
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              6
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Bus 001 Device 005: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
Bus 001 Device 003: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idProduct          0x9512 SMC9512/9514 USB Hub
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0610 4-port hub
  bcdDevice           32.98
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.09
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
The kernel crash occurs when an GSM Modem (tty_ACM0 - ACM6) is connected to the internal USB Port AND I2C-0 is enabled (All function when GSM Modem is connected to External USB Ports) .
In config.txt - #dtparam=i2c_vc=on Therefore I2C-0 is disabled
Connect GSM Modem to Internal USB Port 1
dmesg ..
[  292.141832] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[  295.951856] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
[  296.092124] usb 1-1.3: New USB device found, idVendor=1519, idProduct=0020
[  296.092136] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  296.092144] usb 1-1.3: Product: 7 CDC-ACM
[  296.092152] usb 1-1.3: Manufacturer: Comneon
[  296.092160] usb 1-1.3: SerialNumber: 865789024159123
[  296.194906] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[  296.205050] cdc_acm 1-1.3:1.2: ttyACM1: USB ACM device
[  296.214219] cdc_acm 1-1.3:1.4: ttyACM2: USB ACM device
[  296.216502] cdc_acm 1-1.3:1.6: ttyACM3: USB ACM device
[  296.222813] cdc_acm 1-1.3:1.8: ttyACM4: USB ACM device
[  296.224567] cdc_acm 1-1.3:1.10: ttyACM5: USB ACM device
[  296.226456] cdc_acm 1-1.3:1.12: ttyACM6: USB ACM device
[  296.227235] usbcore: registered new interface driver cdc_acm
[  296.227238] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
lsusb -t
        |__ Port 3: Dev 7, If 0, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 1, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 2, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 3, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 4, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 5, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 6, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 7, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 8, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 9, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 10, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 11, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 12, Class=Communications, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 13, Class=CDC Data, Driver=cdc_acm, 480M
        |__ Port 3: Dev 7, If 14, Class=Vendor Specific Class, Driver=, 480M
Power On , Power off , Power On , Test GSM Modem - Functional
In config.txt - dtparam=i2c_vc=on Therefore I2C-0 is enabled
[  OK  ] Started Show Plymouth Reboot Screen.
[  OK  ] Stopped DINGO server.
         Stopping /etc/rc.local Compatibility...
[  OK  ] Stopped /etc/rc.local Compatibility.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed triggerhappy.socket.
[  OK  ] Closed Syslog Socket.
[  OK  ] Stopped Forward Password Requests to Plymouth Directory Watch.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target System Initialization.
         Stopping Update UTMP about System Boot/Shutdown...
         Stopping Network Time Synchronization...
         Stopping Load/Save Random Seed...
[  OK  ] Stopped target Swap.
[  OK  ] Stopped target Encrypted Volumes.
[  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
         Stopping Restore / save the current clock...
[  OK  ] Stopped target Network is Online.
[  OK  ] Stopped target Network.
         Stopping ifup for eth0...
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Restore / save the current clock.
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped ifup for eth0.
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
[  OK  ] Stopped target Local File Systems.
         Unmounting /boot...
         Unmounting /run/user/1000...
[  OK  ] Unmounted /boot.
[  OK  ] Stopped File System Check on /dev/disk/by-partuuid/a9c7a35b-01.
[  OK  ] Removed slice system-systemd\x2dfsck.slice.
[  OK  ] Unmounted /run/user/1000.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Reached target Shutdown.
[  226.330486] reboot: Restarting system
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.41-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1023 SMP Tue Aug 8 16:00:15 BST 2017
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi Compute Module 3 Rev 1.0
[    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] percpu: Embedded 14 pages/cpu @ba35c000 s25600 r8192 d23552 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 240555
[    0.000000] Kernel command line: bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:FC:F3:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a9c7a35b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 940360K/970752K available (7168K kernel code, 484K rwdata, 2012K rodata, 1024K init, 778K bss, 22200K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
[    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
[    0.000000]       .data : 0x80c00000 - 0x80c79094   ( 485 kB)
[    0.000000]        .bss : 0x80c7b000 - 0x80d3da64   ( 779 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000023] Switching to timer-based delay loop, resolution 52ns
[    0.000296] Console: colour dummy device 80x30
[    0.001202] console [tty1] enabled
[    0.001246] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001313] pid_max: default: 32768 minimum: 301
[    0.001645] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001687] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002581] Disabling cpuset control group subsystem
[    0.002739] CPU: Testing write buffer coherency: ok
[    0.002800] ftrace: allocating 22396 entries in 66 pages
[    0.049257] CPU0: update cpu_capacity 1024
[    0.049309] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.049370] Setting up static identity map for 0x100000 - 0x100034
[    0.051240] CPU1: update cpu_capacity 1024
[    0.051247] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.051927] CPU2: update cpu_capacity 1024
[    0.051933] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.052597] CPU3: update cpu_capacity 1024
[    0.052604] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.052691] Brought up 4 CPUs
[    0.052863] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.052892] CPU: All CPU(s) started in HYP mode.
[    0.052918] CPU: Virtualization extensions available.
[    0.053741] devtmpfs: initialized
[    0.064403] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.064718] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.064780] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.065337] pinctrl core: initialized pinctrl subsystem
[    0.066258] NET: Registered protocol family 16
[    0.068504] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.077323] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.077372] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.077545] Serial: AMBA PL011 UART driver
[    0.079429] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.150174] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[    0.152037] SCSI subsystem initialized
[    0.152217] usbcore: registered new interface driver usbfs
[    0.152319] usbcore: registered new interface driver hub
[    0.152433] usbcore: registered new device driver usb
[    0.159067] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-08-08 12:01
[    0.160482] clocksource: Switched to clocksource arch_sys_counter
[    0.207635] VFS: Disk quotas dquot_6.6.0
[    0.207746] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.207972] FS-Cache: Loaded
[    0.208241] CacheFiles: Loaded
[    0.220385] NET: Registered protocol family 2
[    0.221308] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.221444] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.221656] TCP: Hash tables configured (established 8192 bind 8192)
[    0.221769] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.221836] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.222068] NET: Registered protocol family 1
[    0.222501] RPC: Registered named UNIX socket transport module.
[    0.222533] RPC: Registered udp transport module.
[    0.222561] RPC: Registered tcp transport module.
[    0.222588] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.223567] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.225851] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.241885] FS-Cache: Netfs 'nfs' registered for caching
[    0.242873] NFS: Registering the id_resolver key type
[    0.242935] Key type id_resolver registered
[    0.242963] Key type id_legacy registered
[    0.245381] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.245539] io scheduler noop registered
[    0.245569] io scheduler deadline registered (default)
[    0.245895] io scheduler cfq registered
[    0.251578] BCM2708FB: allocated DMA memory fad10000
[    0.251631] BCM2708FB: allocated DMA channel 0 @ bb80f000
[    0.302204] Console: switching to colour frame buffer device 228x61
[    0.332747] bcm2835-rng 3f104000.rng: hwrng registered
[    0.333013] vc-cma: Videocore CMA driver
[    0.333135] vc-cma: vc_cma_base      = 0x00000000
[    0.333274] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.333430] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.333796] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.349603] brd: module loaded
[    0.358699] loop: module loaded
[    0.358832] Loading iSCSI transport class v2.0-870.
[    0.359534] usbcore: registered new interface driver smsc95xx
[    0.359715] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.587969] Core Release: 2.80a
[    0.588076] Setting default values for core params
[    0.588243] Finished setting default values for core params
[    0.788791] Using Buffer DMA mode
[    0.788898] Periodic Transfer Interrupt Enhancement - disabled
[    0.789067] Multiprocessor Interrupt Enhancement - disabled
[    0.789230] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.789367] Dedicated Tx FIFOs mode
[    0.789808] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[    0.790090] FIQ FSM acceleration enabled for :
[    0.790090] Non-periodic Split Transactions
[    0.790090] Periodic Split Transactions
[    0.790090] High-Speed Isochronous Endpoints
[    0.790090] Interrupt/Control Split Transaction hack enabled
[    0.790737] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058f7fc
[    0.797557] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058fb6c length 36
[    0.804311] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
[    0.811007] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.817791] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.824599] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.831405] Init: Port Power? op_state=1
[    0.838086] Init: Power Port (0)
[    0.844841] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.851576] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.858214] usb usb1: Product: DWC OTG Controller
[    0.864876] usb usb1: Manufacturer: Linux 4.9.41-v7+ dwc_otg_hcd
[    0.871574] usb usb1: SerialNumber: 3f980000.usb
[    0.879041] hub 1-0:1.0: USB hub found
[    0.885811] hub 1-0:1.0: 1 port detected
[    0.893407] usbcore: registered new interface driver usb-storage
[    0.900342] mousedev: PS/2 mouse device common for all mice
[    0.907987] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.914978] bcm2835-cpufreq: min=600000 max=1200000
[    0.921998] sdhci: Secure Digital Host Controller Interface driver
[    0.928615] sdhci: Copyright(c) Pierre Ossman
[    0.937454] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[    0.944430] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.951654] ledtrig-cpu: registered to indicate activity on CPUs
[    0.958424] hidraw: raw HID events driver (C) Jiri Kosina
[    0.965406] usbcore: registered new interface driver usbhid
[    0.972247] usbhid: USB HID core driver
[    0.979827] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[    0.988623] Initializing XFRM netlink socket
[    0.995596] NET: Registered protocol family 17
[    1.002763] Key type dns_resolver registered
[    1.009939] Registering SWP/SWPB emulation handler
[    1.017565] registered taskstats version 1
[    1.024704] vc-sm: Videocore shared memory driver
[    1.031661] [vc_sm_connected_init]: start
[    1.039136] [vc_sm_connected_init]: end - returning 0
[    1.051205] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.996006] console [ttyAMA0] enabled
[    2.010233] sdhost: log_buf @ bad07000 (fad07000)
[    2.042518] Indeed it is in host mode hprt0 = 00021501
[    2.140511] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.143009] random: fast init done
[    2.163422] of_cfs_init
[    2.172966] of_cfs_init: OK
[    2.183096] Waiting for root device PARTUUID=a9c7a35b-02...
[    2.250509] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.264146] Indeed it is in host mode hprt0 = 00001101
[    2.361254] mmc0: new high speed MMC card at address 0001
[    2.374313] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
[    2.385977] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
[    2.399000] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
[    2.411953] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
[    2.425898]  mmcblk0: p1 p2
[    2.511982] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[    2.525581] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.539595] usb 1-1: Product: USB2.0 Hub
[    2.551459] hub 1-1:1.0: USB hub found
[    2.560460] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.560595] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.567905] devtmpfs: mounted
[    2.601450] hub 1-1:1.0: 4 ports detected
[    2.602748] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[    2.940532] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.022432] systemd[1]: System time before build time, advancing clock.
[    3.080922] usb 1-1.1: New USB device found, idVendor=0424, idProduct=9512
[    3.095142] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.110609] hub 1-1.1:1.0: USB hub found
[    3.121866] hub 1-1.1:1.0: 3 ports detected
[    3.141277] NET: Registered protocol family 10
[    3.169338] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.204325] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    3.230532] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[    3.230771] systemd[1]: Detected architecture arm.
[    3.282864] systemd[1]: Set hostname to <DINgo>.
[    3.358643] uart-pl011 3f201000.serial: no DMA platform data
[    3.384683] usb 1-1.2: New USB device found, idVendor=10c4, idProduct=ea71
[    3.399308] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=7
[    3.414687] usb 1-1.2: Product: CP2108 Quad USB to UART Bridge Controller
[    3.429616] usb 1-1.2: Manufacturer: Silicon Labs
[    3.442146] usb 1-1.2: SerialNumber: D0B700E9497FC1A511E6931A8FD1868
[    3.530536] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[    3.680971] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.695754] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.713914] smsc95xx v1.0.5
[    3.737503] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.764386] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.788245] systemd[1]: Listening on udev Kernel Socket.
[    3.811633] systemd[1]: Reached target Swap.
[    3.820511] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[    3.844317] smsc95xx 1-1.1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fc:f3:04
[    3.869448] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.895548] systemd[1]: Created slice User and Session Slice.
[    3.919588] systemd[1]: Listening on Syslog Socket.
[    3.969706] usb 1-1.3: New USB device found, idVendor=1519, idProduct=0020
[    3.969716] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.969722] usb 1-1.3: Product: 7 CDC-ACM
[    3.969729] usb 1-1.3: Manufacturer: Comneon
[    3.969735] usb 1-1.3: SerialNumber: 865789024159123
[    4.214418] i2c /dev entries driver
[    4.241805] usbcore: registered new interface driver usbserial
[    4.241892] usbcore: registered new interface driver usbserial_generic
[    4.241970] usbserial: USB Serial support registered for generic
[    4.378419] PPP generic driver version 2.4.2
[    4.432821] usbcore: registered new interface driver option
[    4.447404] usbserial: USB Serial support registered for GSM modem (1-port)
[    4.488448] Unable to handle kernel paging request at virtual address 55555565
[    4.503292] pgd = b912c000
[    4.513454] [55555565] *pgd=00000000
[    4.524715] Internal error: Oops: 5 [#1] SMP ARM
[    4.536622] Modules linked in: rfkill(+) option usb_wwan ppp_async ppp_generic slhc crc_ccitt usbserial i2c_dev ip_tables x_tables ipv6
[    4.556753] CPU: 2 PID: 120 Comm: systemd-modules Not tainted 4.9.41-v7+ #1023
[    4.571455] Hardware name: BCM2835
[    4.582243] task: b9160ec0 task.stack: b9182000
[    4.594223] PC is at kernfs_link_sibling+0x5c/0xe0
[    4.606443] LR is at kernfs_add_one+0xa0/0x168
[    4.618155] pc : [<802ea244>]    lr : [<802eae88>]    psr: 20000013
[    4.618155] sp : b9183c30  ip : b9183c48  fp : b9183c44
[    4.643823] r10: 00000000  r9 : 00a0003a  r8 : 00000001
[    4.656003] r7 : b9e49fa0  r6 : b9e49fa0  r5 : b93ddb40  r4 : 55555555
[    4.669404] r3 : a1ff001c  r2 : a1ff0014  r1 : b3697df7  r0 : b93dcc40
[    4.682782] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[    4.696857] Control: 10c5383d  Table: 3912c06a  DAC: 00000055
[    4.709567] Process systemd-modules (pid: 120, stack limit = 0xb9182210)
[    4.723331] Stack: (0xb9183c30 to 0xb9184000)
[    4.734735] 3c20:                                     b93ddb40 b93ddb40 b9183c7c b9183c48
[    4.750126] 3c40: 802eae88 802ea1f4 b9e49fa0 802eabcc 80000001 b9e49fa0 b9183c7c b9183c68
[    4.765487] 3c60: 802eabcc b93ddb40 b93dda50 b9e49fa0 b9183c9c b9183c80 802ec960 802eadf4
[    4.780933] 3c80: 00000418 b93dda50 b91a2400 b93dcbc0 b9183cc4 b9183ca0 802ed708 802ec918
[    4.796357] 3ca0: 00000001 b91a2408 b91a2400 00000000 00000000 80d10534 b9183cd4 b9183cc8
[    4.811855] 3cc0: 802ed78c 802ed68c b9183d14 b9183cd8 804f8674 802ed760 b9183cf4 b9183ce8
[    4.827414] 3ce0: 8022cc20 8025f6fc b9183d14 00000000 b91a2400 b91a2408 7f0e4e6c 00000000
[    4.842989] 3d00: 00a0003a 00000000 b9183d3c b9183d18 804f8b34 804f83fc 00000000 7f0e4e6c
[    4.843005] 3d20: 7f0e4e78 80c54964 00000000 46c235dc b9183d6c b9183d40 804f8bec 804f8a80
[    4.843015] 3d40: 00000000 8097017c b9183d78 b9183d58 807175b8 b9183d78 00000001 80d0e2e0
[    4.843025] 3d60: b9183da4 b9183d70 804ed0c4 804f8bc4 00000000 8097017c 7f0e46e8 b9183d88
[    4.843035] 3d80: 804fc394 00000000 7f0e9000 b93dcb00 7f0e4fc0 00000001 b9183dbc b9183da8
[    4.843045] 3da0: 7f0e9054 804ecf74 00000000 7f0e4fc0 b9183e3c b9183dc0 80101bf0 7f0e900c
[    4.843057] 3dc0: 00000000 397ff000 8022d0a0 b9092780 00000e06 397ff000 8024e9fc b9092700
[    4.843067] 3de0: 00000e06 8025e514 b9183e3c b9183df8 8025e514 80715cec 8025f8d4 8025ed78
[    4.843077] 3e00: 00000001 00000e06 b93dcb40 a0000013 bd605000 7f0e4fc0 00000001 b93dcb00
[    4.843088] 3e20: 7f0e4fc0 00000001 46c235dc b93dca48 b9183e64 b9183e40 80209f2c 80101bac
[    4.843098] 3e40: b9183e64 b9183e50 8024eaf0 b9183f3c 00000001 b93dca40 b9183f14 b9183e68
[    4.843108] 3e60: 801a3588 80209ec4 7f0e4fcc 00007fff 7f0e4fc0 801a0c6c b9183ea4 7f0e51ac
[    4.843118] 3e80: bd608284 7f0ebe7c 7f0e51fc 00000002 7f0e50d4 7f0e5008 b9183ee4 b9183ea8
[    4.843128] 3ea0: 80276d48 80276bc8 bd605000 7f0e3ea0 0000000e 00000000 00000000 00000000
[    4.843137] 3ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.843147] 3ee0: 00000000 00000000 7fffffff 00000000 00000005 76df9a18 0000017b 7fffffff
[    4.843157] 3f00: 00000000 00000000 b9183fa4 b9183f18 801a3ea0 801a1bc8 7fffffff 00000000
[    4.843167] 3f20: 00000003 8022d24c b9183f74 bd605000 000094c4 00000000 00000002 bd605000
[    4.843177] 3f40: 000094c4 bd60dd6c bd6096ca bd60b304 000031fc 000043fc 00000000 00000000
[    4.843187] 3f60: 00000000 00002e7c 0000002d 0000002e 00000023 00000027 00000019 00000000
[    4.843197] 3f80: 0000017b c4427500 00000000 00000000 80108244 b9182000 00000000 b9183fa8
[    4.843207] 3fa0: 801080c0 801a3e10 c4427500 00000000 00000005 76df9a18 00000000 01440be0
[    4.843217] 3fc0: c4427500 00000000 00000000 0000017b 00020000 00421c40 00000000 01440be0
[    4.843227] 3fe0: 7ef10370 7ef10360 76df13d0 76d4d590 60000010 00000005 00000000 00000000
[    4.843265] [<802ea244>] (kernfs_link_sibling) from [<802eae88>] (kernfs_add_one+0xa0/0x168)
[    4.843282] [<802eae88>] (kernfs_add_one) from [<802ec960>] (kernfs_create_link+0x54/0x78)
[    4.843304] [<802ec960>] (kernfs_create_link) from [<802ed708>] (sysfs_do_create_link_sd+0x88/0xd4)
[    4.843321] [<802ed708>] (sysfs_do_create_link_sd) from [<802ed78c>] (sysfs_create_link+0x38/0x44)
[    4.843338] [<802ed78c>] (sysfs_create_link) from [<804f8674>] (device_add+0x284/0x57c)
[    4.843354] [<804f8674>] (device_add) from [<804f8b34>] (device_create_groups_vargs+0xc0/0xd0)
[    4.843368] [<804f8b34>] (device_create_groups_vargs) from [<804f8bec>] (device_create_with_groups+0x34/0x3c)
[    4.843384] [<804f8bec>] (device_create_with_groups) from [<804ed0c4>] (misc_register+0x15c/0x1a8)
[    4.843433] [<804ed0c4>] (misc_register) from [<7f0e9054>] (rfkill_init+0x54/0x90 [rfkill])
[    4.843481] [<7f0e9054>] (rfkill_init [rfkill]) from [<80101bf0>] (do_one_initcall+0x50/0x184)
[    4.843498] [<80101bf0>] (do_one_initcall) from [<80209f2c>] (do_init_module+0x74/0x1e4)
[    4.843515] [<80209f2c>] (do_init_module) from [<801a3588>] (load_module+0x19cc/0x2108)
[    4.843533] [<801a3588>] (load_module) from [<801a3ea0>] (SyS_finit_module+0x9c/0xac)
[    4.843551] [<801a3ea0>] (SyS_finit_module) from [<801080c0>] (ret_fast_syscall+0x0/0x1c)
[    4.843562] Code: e1a02004 e5934000 e3540000 0a00000b (e5943010)
[    4.843635] ---[ end trace 9518e1498d9bc1e2 ]---
I understand that this is a long post but I wanted to ensure that all the information regarding this USB / I2C-0 kernel
Just to summarize :-
1. This problem does not appear on the Raspberry PI Compute Module 1
2. The problem only appears on the Raspberry PI Compute Module 3 when :-
a) GSM Modules is connected to Internal USB - (via GL852G Port)
AND
b) I2C-0 is Enabled
Thank you for your patience
rzusman
Re: Kernel Crash with GSM Modem AND I2C-0 Enabled
Wed Nov 29, 2017 3:54 am
Check your power supply!
GO-IOT
Wed Nov 29, 2017 9:23 am
I should have mentioned that we are using a 5V @5A PSU. Very low noise observed on oscilloscope
gsh
Thu Dec 07, 2017 11:01 am
I would suggest you debug the kernel using serial debug (kgdb) then add kgdbwait and kdbgoc to the cmdline. Then you should be able to debug the kernel when the error occurs and find out what went wrong...
Since it's related to both USB and I2C I'd assume there was some interaction between them, but nothing springs to mind immediately
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
Return to “Compute Module”
Who is online
Users browsing this forum: No registered users and 2 guests
