Smelter
Re: raspberry pi doesn't boot [solved]
Wed Dec 31, 2014 3:21 pm
As a "sub note" to the "Moderator update" :-
The error does occur with "NOOBS 1.3 or with Rasbian" :x
The solution of " placing a jumper over the Re pins solves the issue" does work, but to make make sure you get the right jumper position you link the "green" highlighted pin on page 8 of the manual with the pin in the middle row above it.
Just watch out when it does start up as all 6 blue LEDs light up, threatening retina burn 8-)
Return to “GertDuino”
Who is online
Users browsing this forum: No registered users and 1 guest
