racpi
reset_on / off no longer work
Wed Feb 25, 2015 8:57 am
just updated and upgraded my raspian to the latest version and now gerts reset_on an reset_off scripts no longer function.
in fact the reset jumper needs to be removed before the gertduino 328 will operate. I assume this will make uploading sketches difficult too.
any tips on how to remedy this would be appreciated.
richard
panik
Re: reset_on / off no longer work
Thu Feb 26, 2015 10:18 pm
Confirmed. To have it work again, disable the Device Tree. Do this by adding 'device_tree=' to the end of '/boot/config.txt'.
sudo nano /boot/config.txt
Scroll down to the end, and add:
device_tree=
ctrl-x, y, enter, and reboot.[/s] Hopefully a temporary solution, but it works for now.
Edit: Probably even better, use raspi-config to disable it.
sudo raspi-config
-> 8 Advanced Options
-> A5 Device Tree
-> [No]
Microcontroller addon boards and software for Raspberry Pi A+/B+/Pi2:
- ARMinARM: ARM Cortex-M3 (STM32)
- AVRPi: ATmega32U4 & ATmega328 ("Arduino")
http://www.onandoffables.com
racpi
Sat Feb 28, 2015 5:34 am
thanks for that , problem resolved by disabling device tree
Sat Feb 28, 2015 10:40 am
racpi wrote:thanks for that , problem resolved bypassed by disabling device tree
You need to look deeper, there will come a time when you can't run a Raspberry Pi without the device tree.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
panik
Sat Feb 28, 2015 2:33 pm
Very true, eventually someone will have to come up with a better answer. This solution will not last forever.
Gert van Loo
Mon Mar 02, 2015 11:07 am
I would say this is an error in the Rasbian image.
My reset-on/reset-off code does not use an of the peripheral addresses.
It uses the /sys/class/gpio devices which SHOULD be transparency to those changes.
(What that I mean I expect the /sys/class/gpio device to use the device tree.)
This is the code:
#!/usr/bin/sudo bash
# Set GPIO pin 8, low activating Arduino reset
sudo echo "8" >/sys/class/gpio/export
sudo echo "out" >/sys/class/gpio/gpio8/direction
sudo echo "0" >/sys/class/gpio/gpio8/value
sudo echo "8" >/sys/class/gpio/unexport
panik
Mon Mar 02, 2015 12:52 pm
Gert van Loo wrote:I would say this is an error in the Rasbian image.
When I asked (http://www.raspberrypi.org/forums/viewt ... 44&t=99113), it was suggested that Raspbian is now doing 'the right thing', where it wasn't before the Device Tree.
With the Device Tree, when a pin is unexported it returns back to an input ('the right thing'). The 'reset_off' script relies on the fact that it stays an output and remembers the '1' written to it (the old 'not the right thing').
It's probably in combination with the voltage level conversion that the 10K AVR reset pullup isn't strong enough to keep the reset pin high. Removing the reset jumper makes the pullup kick in. The 3.3V AVR on the Gertboard still works with the Device Tree, but doesn't need the on/off scripts in the first place.
Not unexporting the pin makes a mess of things the next time you run the script, so I haven't experimented with that much further. Also, since my question in the beforementioned topic, there have been more Raspbian updates which magically made my software work again (with the Device Tree, making my original question redundant for my use case).
I hope this helps.
