Getting Started
Posted: Sun Mar 02, 2014 6:40 pm
by NicoVanDerDussen
I'm impressed with Mathematica looking at what others are doing with it.
But how does one get started? I find the Mathematica documentation pages a bit overwhelming without a clear path to get going :(
The "blank" page when one opens Mathematica is not of great help :)
I found this intro guide http://nvdd.info/1dQtC7n from MIT, and I did manage to plot some graphs :)
Is there any recommended route to get going?
Nico
MOD EDIT: See Mathematica Usage Guide
Re: Getting Started
Posted: Sun Mar 02, 2014 9:43 pm
by DeeJay
This sounds as though it might be a starting point?
Have you been staring at the Mathematica and Wolfram Language icons on your Raspbian install, and wondering where to get started? We’ll be featuring several guest posts from Wolfram Research in the coming weeks, so you can start to get to work with them. This first, introductory post is from Arnoud Buzing.
http://www.raspberrypi.org/archives/5623
Re: Getting Started
Posted: Tue Mar 04, 2014 1:37 am
by mob-i-l
I made a video with Mathematica on Raspberry Pi and that shows some examples and the captions show what I type. You could buy or borrow an old book about Mathematica.
Re: Getting Started
Posted: Wed Mar 05, 2014 8:26 pm
by mgscheue
I really like Roozbeh Hazrat's book, Mathematica: A Problem-Centered Approach. He works through small but interesting examples,to illustrate how to solve problems using Mathematica, like finding all perfect numbers up to 10,0000.
Re: Getting Started
Posted: Mon Mar 10, 2014 10:48 pm
by mob-i-l
mgscheue wrote:I really like Roozbeh Hazrat's book, Mathematica: A Problem-Centered Approach.
I borrowed that as a pdf-file from Lund University Library. There was one example that didn't work in Mathematica for Raspberry Pi:
FullSimplify[Tan[3 Pi/11] + 4 Sin[2 Pi/11]]
This should simplify to Sqrt[11], but it does only simplify to:
Cot[(5 \[Pi])/22] + 4 Sin[(2 \[Pi])/11].
In that book they are using an older version of Mathematica and it's strange that our version cannot do this simplification. Maybe there is some setting one could do to make this work on Raspberry Pi.
