Remote use
Posted: Sun Dec 01, 2013 2:42 pm
by Durazell
I was just wondering if there is a web frontend or some other way that could be used to connect to wolfram that is running on pi. I don't have the device here and using VNC is *really* laggy due to relatively low upload bandwidth. it seems "Remote Development Kit" is no use too as it does absolutely nothing when opened in cdf player.
Re: Remote use
Posted: Sun Dec 01, 2013 5:15 pm
by geev03
I find it easy to remote access Raspberry Pi using Microsoft Remote Desktop --
https://itunes.apple.com/us/app/microso ... d715768417.
The upload speed, ( thanks BT Infinity ), is about 15Mbps , so remote looks almost as good as the access from internal network.
Re: Remote use
Posted: Mon Dec 02, 2013 2:28 am
by dennisw
I use X11 forwarding over ssh, but it's a fast connection. You should try it to see how it works for you.
Re: Remote use
Posted: Mon Dec 02, 2013 1:42 pm
by algorithm
Remote Desktop works OK for me, too. It requires installation of the xrdp package (sudo apt-get install xrdp) or at least that's one way of enabling it.
Re: Remote use
Posted: Tue Dec 03, 2013 11:25 am
by Silver_fox
Algorithm, have tried using that "sudo apt-get install xrdp" with latest version of Raspbian but just keep getting error messages.
Seems to be looking for a different path.
Any suggestions would be most helpful or is it possible to install the individual files I would require to run xrdp separatel.
Re: Remote use
Posted: Tue Dec 03, 2013 5:47 pm
by algorithm
Did you first do "sudo apt-get update" to sync the local package info? Before install/upgrade/dist-upgrade, always first update. See "man apt-get". Maybe now try this, in order:
sudo apt-get clean
sudo apt-get update
sudo apt-get -y upgrade
sudo apt-get -f install xrdp
Re: Remote use
Posted: Tue Dec 03, 2013 9:09 pm
by Silver_fox
Thanx I tried that but it didn't work.
Seems the path in err
http://mirror director.raspbain.org wheezy Release.gpg was having a temporary failure resolving 'mirror director.raspbain.org'
Any other ideas would be most welcome
Re: Remote use
Posted: Thu Dec 05, 2013 10:48 am
by algorithm
Assuming "raspbain" is your typo and not the repo list maintainer's, I don't know. Possibly also beyond the scope of this Mathematica sub-forum.
