Raspbian init script bug
Posted: Sat Nov 30, 2013 2:50 am
by gdt
Hi folks, Not sure which bugtracker to log this against, so I'll simply record it here for reference by others.
The file /etc/init.d/mathkernel doesn't contain a LSB header and this causes issues when adding or removing other daemons using update-rc.d (usually called by as part of the installation or removal of the a daemon's package).
Solve this by adding a header. Specifically, add this to the start of /etc/init.d/mathkernel
#!/bin/sh
# start/stop mathematica daemon.
### BEGIN INIT INFO
# Provides: mathematica
# Required-Start: $network $local_fs
# Required-Stop: $network $local_fs
# Default-Start: S 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Mathematica remote services
# Description: Allows remote use of Mathematica.
### END INIT INFO
Re: Raspbian init script bug
Posted: Mon Dec 02, 2013 2:54 pm
by kurtdcobain
thank you
Posted: Mon Dec 02, 2013 3:37 pm
by jojopi
gdt wrote:The file /etc/init.d/mathkernel doesn't contain a LSB header and this causes issues when adding or removing other daemons using update-rc.d (usually called by as part of the installation or removal of the a daemon's package).
What issues? I just see a harmless warning.
Posted: Mon Dec 02, 2013 4:33 pm
by alexatwri
Well, that's embarrassing. That should be fixed in the next update. Thanks for bringing it to our attention...
Posted: Tue Jan 14, 2014 4:20 am
by gdt
jojopi wrote:What issues? I just see a harmless warning.
It's harmless as long as you don't have packages which cause a unresolvable loop. For example, attempt to install both mathkernel and watchdog. One of the two services won't start.
Posted: Sat Mar 08, 2014 10:23 am
by algorithm
Has this init.d script been removed from newer installations? I just re-installed wolfram-engine and there is nothing related in /etc/init.d
OT: desktop shortcuts still not automatically generated. Works from the menu shortcuts, though. Edit: ah sorry, maybe creating desktop shortcuts is not part of the installation anyway. If you want, a desktop icon is easily added by right-clicking the Mathematica icon in the Education menu and selecting "Add to desktop." Never mind this off-topic paragraph!
Posted: Tue Mar 25, 2014 8:50 pm
by alexatwri
algorithm wrote:Has this init.d script been removed from newer installations? I just re-installed wolfram-engine and there is nothing related in /etc/init.d
Yes. That particular script was not supposed to be present in the first place. There should be a much more robust solution for using a daemonized kernel in the near future.
Posted: Wed Mar 26, 2014 9:28 am
by algorithm
alexatwri wrote:algorithm wrote:Has this init.d script been removed from newer installations? I just re-installed wolfram-engine and there is nothing related in /etc/init.d
Thanks.
Posted: Tue Apr 08, 2014 8:45 pm
by paralight
well, thanks again , got same error after a "sudo update-rc.d pyload defaults"
