Where's wolfram-engine? Messed up sources.list?
Posted: Fri Nov 22, 2013 3:57 pm
by thradtke
Hi *,
tried & failed to locate package 'wolfram-engine' in archive.raspbian.org. Is there a trick?
Update lists and upgrade system worked afaict. Help, please
Thanks,
Thomas
Re: Where's wolfram-engine? Messed up sources.list?
Posted: Fri Nov 22, 2013 5:50 pm
by MoosePi
You need to have the Raspberry Pi Foundations Raspbian Wheezy ARMHF installed, there has been other posts regards this issue in the Matmetica Forum:
http://www.raspberrypi.org/phpBB3/viewforum.php?f=94
Posted: Fri Nov 22, 2013 6:04 pm
by thradtke
I have Raspbian, i.e. hardfloat Wheezy, since it came out.
My system is kind of messy. Still use the first image, updated regularly by my offline repos and the Github firmware. Today I have the opportunity to directly connect to the internet, so I thought I could give updating a try, and it seemingly worked ... otoh, I can't even locate the package wolfram-engine by looking through archive.raspbian.org (searched main, contrib, nonfree). You know where it is located?
What am I missing here?
Posted: Fri Nov 22, 2013 6:42 pm
by MoosePi
Did you read the other posts at the link I posted ??
My sources list is listed here:
http://www.raspberrypi.org/phpBB3/viewt ... 95&t=61489
This is my output on latest debian wheezy fully updated:
nano /etc/apt/sources.list
/deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free r$
Posted: Fri Nov 22, 2013 9:14 pm
by dennisw
It appears to be in raspberrypi.org's repository but not in raspbian's.
Try:
http://archive.raspberrypi.org/debian/p ... am-engine/
My sources.list:
deb
http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Posted: Sat Nov 23, 2013 6:50 am
by thradtke
MoosePi wrote:Did you read the other posts at the link I posted ??
Yes, thanks. I hope nothing slipped my attention.
Posted: Sat Nov 23, 2013 6:54 am
by thradtke
Great, thanks
. It's beyond me why mirrordirector.raspbian.org points you to archive.raspberrypi.org. I guess you have an entry in /etc/apt/sources.list.d? I don't, but I'll try to create one.
Edit: That did the trick ... d/l'ing 400+ MiBs now
Posted: Sat Nov 23, 2013 8:09 am
by geev03
Here it is a 207 MB download..
<p>
Posted: Sat Nov 23, 2013 11:53 am
by thradtke
Enjoy Wolfram ... as much as I do
Posted: Sat Nov 23, 2013 12:14 pm
by dennisw
Yes,
$ cat /etc/apt/sources.list.d/wolfram.list
# Wolfram Research, Inc. APT Repository (for WolframEngine)
deb http://repository.wolfram.com/raspbian/ stable non-free
$ cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ wheezy main
Posted: Sat Nov 23, 2013 12:50 pm
by thradtke
Thanks again for your effort, Dennis. This is very helpful.
Posted: Sat Nov 23, 2013 1:26 pm
by geev03
thradtke wrote:Enjoy Wolfram ... as much as I do
Yes, even on a mobile phone...
Posted: Sun Nov 24, 2013 9:28 am
by thradtke
It appears Java cannot be started from Mathematica on 256MB models, correct?
Output from trying W|A queries (just one out of many error messages quoted):
During evaluation of In[1]:= LinkObject::linkn: Argument LinkObject['/opt/Wolfram/WolframEngine/10.0/SystemFiles/Java/Linux-ARM/bin/java' -classpath "/opt/Wolfram/WolframEngine/10.0/SystemFiles/Links/… -Djava.util.prefs.PreferencesFactory=com.wolfram.jlink.DisabledPreferencesFactory com.wolfram.jlink.Install -init "/tmp/m00000130571",73,4] in LinkReadyQ[LinkObject['/opt/Wolfram/WolframEngine/10.0/SystemFiles/Java/Linux-ARM/bin/java' -classpath "/opt/Wolfram/WolframEngine/10.0/SystemFiles/… .util.prefs.PreferencesFactory=com.wolfram.jlink.DisabledPreferencesFactory com.wolfram.jlink.Install -init "/tmp/m00000130571",73,4]] has an invalid LinkObject number; the link may be closed.
Of course, the Oracle JDK is installed.
Time to update to a 512MB model :-/.
Posted: Sun Nov 24, 2013 1:55 pm
by mob-i-l
I use Raspbian from the latest NOOBS and it is most updated and upgraded, and yet sudo apt-get install can only find mathematica-fonts. I think the repositories should be fixed automatically.
I succeeded in getting it to run by downloading:
wget
http://repository.wolfram.com/raspbian/ ... _armhf.deb
And installing:
sudo dpkg -i wolfram-
engine_10.0.0+2013112003_armhf.deb
The menus are correctly installed and I tried both the GUI and CLI versions.
