Connect 2 Pi's with a router / parallelcomputing
Posted: Tue Jul 14, 2015 7:43 am
I want to play a bit with parallelcomputing...:
I have two Pi's, one via cable at my router, the other one connected with Wlan...what do I need to do, to get access to the second Pi inside Mathematica?
The 'slave' has installed Raspbian and 'wolfram'(command-line only, but I get the same result if I autostart the complete Wolfram-notebook with 'mathematica') is autostarted - but what next?
Whatever I do or setup in Mathematica on the Pi that I use, it outputs at startup....can someone explain me please what to do, to get access to the 'kernels' of the second Pi for more evaluating-power?
Is it possible at all to use more than 4 kernels with the free-license on the Pi? (Sys-Info shows 16 subkernels are possible)
If so, how do I connect them correct?
I already added a new kernel and have set the Ip my router shows as machine name in its properties. But what to do with all the other options there exactly?
The kernel New Kernel failed to connect to the front end. (Error = MLECONNECT). You should try running the kernel connection outside the front end.Is it possible at all to use more than 4 kernels with the free-license on the Pi? (Sys-Info shows 16 subkernels are possible)
