tinylcd
Re: 3.5 Inch TFT Display for Raspberry Pi
Tue Mar 24, 2015 4:36 am
hello
we have not tested it with debian
but one of our client have compiled and tested it with
ARCH linux ARM kernel (linux-raspberrypi-3.18.8-3)
and found it to be working satisfactorily
regards
tinylcd
micahf
Wed Apr 01, 2015 4:38 am
I have a screen that is very similar to this, but i believe this question still applies. Is there any way to scale the screen resolution so that eachpixel displays two pixels? This way, more could fit on the screen, and it would be more usable.
tinylcd
Wed Apr 01, 2015 9:58 am
Hello
as per my knowledge i doubt if we can stretch the screen resolution beyond 480x320 for our 3.5 inch TFT
but we do have a 7 inch screen with pixels as high as 1024x600
you can see them at below link
http://www.neosecsolutions.com//index.p ... c71adc2b85
regards
tinylcd
nopnop2002
Fri Jun 19, 2015 9:12 pm
hello.
I'd like to use this module without fbtft driver.
I'd like to know the model number of the tft controller chip used by this module.
tinylcd
Mon Jun 22, 2015 4:18 am
Hello
we do not recommend it to use without fbtft
because the speed is very slow without fbtft
regards
tinylcd
giorgiofolle
Wed Jul 08, 2015 3:40 pm
Now i read:
The FBTFT drivers are included in the Raspberry Pi Foundation kernel and can be installed with plain rpi-update.
There is one piece missing and that is a DMA capable SPI controller driver to get max performance. So for fbcp and showing movies, the FBTFT kernel still has to be used.
So, the modules are inclusive in the new kernel ? because i have updated my rpi but the screen doesn't works "out of the box"
i have a classic 3.5 screen , no touch
AndyD
Thu Jul 09, 2015 1:02 am
giorgiofolle wrote:So, the modules are inclusive in the new kernel ? because i have updated my rpi but the screen doesn't works "out of the box"
Yes, the modules are now a part of the standard Raspbian kernel, but it is not plug and play. Firstly you need to load the module by adding a line to config.txt. There is a readme file in the /boot/overlay directory.
I use the following:
dtoverlay=tinylcd35,rotate=270
This will create a new display device (/dev/fb1). However, nothing will be displayed by default. If you want the desktop on the LCD you will need to modify a few files to get the desktop to use /dev/fb1 rather than /dev/fb0.
lovermonkey
Thu Oct 15, 2015 2:07 pm
Once you have the drivers installed, is it easy to go for this 3.5 inch screen back to my hdmi?
tinylcd
Sat Oct 17, 2015 4:39 am
Hello
the answer to your query is YES and NO
Yes because
It works as long as you direct your output to the right framebuffer (/dev/fb0 is hdmi, /dev/fb1 is the TFT).
No because
you cannot display two independent images on the two screens
it will be a mirror image
regards
tinylcd
lovermonkey
Mon Oct 19, 2015 9:10 pm
tinylcd wrote:Hello
Yes because
No because
regards
tinylcd
I don't need the hdmi and the 3.5 inch to work at the same time. But I need to be able to switch them without a lot of hassle. I plan to have the 3.5 when on the road, but when I get back I would like to take off the 3.5 and switch to hdmi. How easy is that?
Also when I am on the road I have a terminal that comes up displaying information. How large does the terminal display have to be to fill the screen on this 3.5 inch? If that made sense at all. LOL
Oh and thank you for your help.
tinylcd
Tue Oct 20, 2015 5:04 am
Hello
this can be achieved by using a gpio pin
a slide switch can be connected to a gpio pin
and depending on the high or low status of the GPIO the display fbc can be selected for hdmi(GPIO high) or spi(gpio Low)
regards
tinylcd
lovermonkey
Tue Oct 20, 2015 1:10 pm
tinylcd wrote:Hello
regards
tinylcd
I assume this is something that I would have to tell it via script etc or is it automatic with setup they give you?(Meaning software setup)
tinylcd
Wed Oct 21, 2015 5:32 am
hello
need to incorporate a special setup
for this requirement
regards
tinylcd
Deadpan Robot
Sun Nov 22, 2015 4:31 pm
giorgiofolle wrote: Yes, the modules are now a part of the standard Raspbian kernel, but it is not plug and play. Firstly you need to load the module by adding a line to config.txt. There is a readme file in the /boot/overlay directory.
Could you please give an example of the files you need to modify?
Many thanks in advance for your time,
Juan
AndyD
Sun Nov 22, 2015 8:59 pm
Deadpan Robot wrote:Could you please give an example of the files you need to modify?
Juan
Edit the file /usr/share/X11/xorg.conf.d/99-fbturbo.conf using "sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf" and change the line
Option "fbdev" "/dev/fb0"
to
Option "fbdev" "/dev/fb1"
alzi123
Tue Jan 17, 2017 8:07 am
Hello stevejferry,
I read your post:
>by stevejferry » Tue Jul 15, 2014 7:34 am
>The Pi boots with the LCD as default, the output to the HDMI gets switched off.
>Once the Pi has booted, is it possible to switch between HDMI and LCD output?
>Steve.
Have you solved this problem using the LCD-display parallel to the HDMI output?
I have the same problem at the moment.
Greetings
alzi123
Seanzky
Sat Mar 25, 2017 1:46 am
Is there a way to not use the image I got with these screens and just use Raspbian? If so how?
tothambrus11
Fri May 05, 2017 5:46 pm
1.
wget http://www.waveshare.com/w/upload/4/4b/LCD-show-161112.tar.gz
2.
tar xvf LCD-show-161112.tar.gz
3.
cd LCD-show/
4.
./LCD35-show
If you want to rotate the screen, you can use the following commands:
0 degrees:
cd LCD-show/
./LCD35-show 0
90 degrees:
cd LCD-show/
./LCD35-show 90
180 degrees:
cd LCD-show/
./LCD35-show 180
270 degrees:
cd LCD-show/
./LCD35-show 270
Geekworm
Wed May 10, 2017 3:02 am
:D :D :D
Geekworm Official Store!
Contact: gk@geekworm.net
Know more Raspberry Pi Related Product Information: http://www.raspberrypiwiki.com/index.php/Product_Manual#Raspberry_Pi
batpete73
Tue Dec 05, 2017 7:29 pm
Before we get into the steps make sure you have SSH enabled and can connect to the PI.
enable SSH
sudo raspi-config
1. interface options
a. enable SSH
to get your IP address
ifconfig
verify you can connect via SSH by using putty or some other client
configure PI for the touch screen
sudo raspi-config
1. under advanced options
a.expand filesystem
2. boot options
a.desktop/cli
I.desktop autologin
Install touch screen
download the drivers for the touch screen. Please note these are the newer drivers vs 161112 that everyone else was trying to install along with we are using LCD35B vs just LCD35.
wget http://www.waveshare.com/w/upload/0/00/LCD-show-170703.tar.gz
tar xvf LCD-show-170703.tar.gz
cd LCD-show/
chmod +x LCD35B-show
this next command will reboot the PI and make an attempt to display on the touch screen and if it doesn't work this is why you want SSH enabled so you can switch it back to the HDMI setting.
./LCD35B-show
to toggle between HDMI and the touch screen
HDMI
cd LCD-show/
./LCD-hdmi
touchscreen
cd LCD35B-show/
For screen rotation
0 degrees
cd LCD-show/
./LCD35B-show 0
90 degrees
cd LCD-show/
./LCD35B-show 90
180 degrees
cd LCD-show/
./LCD35B-show 180
270 degrees
cd LCD-show/
./LCD35B-show 270
I did not have to calibrate the touch screen as it was already spot on.
Calibration
If you do require calibration you need to install input-calibrator
sudo apt-get install -y xinput-calibrator
sudo DISPLAY=:0.0 xinput_calibrator
After running these commands, there will be a prompt for four-point calibration shown in the LCD screen. Click the points one by one to finish the touch calibration. Then, the new calibration data will be displayed in the terminal, as shows below. Please get these data for future use.
Doing dynamic recalibration:
Setting new calibration data: 3919, 208, 236, 3913
Enter the following command to edit 99-calibration.conf:
sudo nano /etc/X11/xorg.conf.d/99-calibration.conf
Then, the old calibration data will be displayed in the terminal:
Section "InputClass"
Identifier	"calibration"
MatchProduct	"ADS7846 Touchscreen"
Option	"Calibration"	"160 3723 3896 181"
Option	"SwapAxes"	"1"
EndSection
Modify the calibration data to the new calibration data displayed above):
Option	"Calibration"	"3919 208 236 3913"
EndSection
Press the keys Ctrl+X, and select the option Y to save the modification.
The modification will be valid after rebooting the system. Enter the following command for system reboot:
sudo reboot
enable camera
If you want to enable the camera with it
sudo raspi-config
a. enable camera
Copy camera driver
wget https://www.waveshare.com/w/upload/f/f0/RPi-Camera-Driver-for-GPIO-LCD.zip
then unzip the camera
unzip camera.zip
cd camera
sudo chmod 777 Camera
sudo cp update\ camera/95-stmpe.rules /etc/udev/rules.d/
Create a file called wheezy.list
sudo nano /etc/apt/sources.list.d/wheezy.list
Append
deb http://archive.raspbian.org/raspbian wheezy main
Create a file called 10defaultRelease.
sudo nano /etc/apt/apt.conf.d/10defaultRelease
Append
APT::Default-release \"stable";
Create a file called libsdl.
sudo nano /etc/apt/preferences.d/libsdl
Append
Package: libsdl1.2debian
Pin: release n=jessie
Pin-Priority: -10
Pin: release n=wheezy
Pin-Priority: 900
execute the commands which will enable the camera
sudo apt-get update
sudo apt-get -y --force-yes install libsdl1.2debian/wheezy
sudo apt-get install evtest tslib libts-bin xinput
sudo apt-get install python-pip
sudo apt-get install python2.7-dev
sudo pip install picamera==1.10
sudo reboot
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
you can also get all of this information from the website https://www.waveshare.com/wiki/3.5inch_RPi_LCD_(B)
dliloch
Sat Feb 24, 2018 5:10 pm
I just wanted to add this..I spent several hours fruitlessly trying to get the adafruit 3.5 PITFT working on
Stretch 11/2017 release..with the raspi pi 2 model b v1.1. I am only making this post to perhaps save someone else the time spent! The adafruit jessie code works but I wanted supported code..by luck I tried it on a pi zero wH with the pitft35-resistive overlay and it worked fine.. I’m sure it would also work on a pi3...but have not tried it there..
-don
Return to “For sale”
Who is online
Users browsing this forum: No registered users and 1 guest
