macsboost
Carbon Fiber/Aluminum Motorsport Raspberry Pi Case
Sat Jan 26, 2019 9:02 pm
Greetings. Check out the highest performance Raspberry pi case in the world!
Now in stock!
-Carbon fiber bonnet
-Precision machined from 6061 Aluminum
-Anodized silver matte
-Integral Monoblock heatsink case feature for cpu and ethernet
-Optimized for the Pi 3b+
-Stainless steel power switch with leads
-Blue ring LED indicator
-Extra gravity with low CG optimization
-Pi R Squared design
-Wind tunnel tested
-Optimum (CL) and minimum (CD) at 45 deg angles of attack
-Compatible with the Pi 3B+ form factor.
https://www.macsboost.com/product/mcpi- ... y-pi-case/
https://www.macsboost.com/2019/01/24/mc ... y-pi-case/
IMG_2687 (Custom).jpg (39.69 KiB) Viewed 1321 times
The attachment carbon pi case.PNG is no longer available
https://www.youtube.com/watch?v=hM_7OLqvmWI
carbon pi case.PNG (130.66 KiB) Viewed 1827 times
macsboost
Re: Carbon Fiber/Aluminum Motorsport Raspberry Pi Case
Thu Mar 07, 2019 3:55 pm
Cases are back from anodizing. we can almost taste the Raspberry Pi!
https://www.macsboost.com/2019/03/07/we ... eview=true
MACSBOOST McPi Raspberry Pi Case Carbon Fiber Aluminum.JPG (31.12 KiB) Viewed 1499 times
mahjongg
Sat Mar 09, 2019 1:01 pm
please stop bumping your post. if you want to add pictures edit them into older posts.
you have had warnings.
Return to “For sale”
