RaspberryShake
Personal seismograph Raspberry Shake
Tue Jun 28, 2016 9:46 pm
Hi, my name is Francesca and I'm here to talk to you about Raspberry Shake. This is a personal seismograph that can record vibrations coming from the ground. We're going to launch a campaign on Kickstarter coming soon and I would like you to invite to our Raspberry Shake main site www.raspberryshake.org There, you will find more information about the shield. Please, subscribe to our mailing list and enjoy watching the earth move with Raspberry Shake.
jbeale
Re: Personal seismograph Raspberry Shake
Sun Dec 11, 2016 8:14 pm
I joined the kickstarter project, and recently took delivery of the hardware. This is a really neat gadget! I've recorded several quakes already, both small local ones (eg. M2.3 at 20 km) and a large distant one (M7.8 at 4000 km). The online network view of other people's stations is also pretty impressive. It will also pick up cars in the street, my washing machine, and just now trying to figure out another signal which may be the next-door neighbor's washing machine.
It's neat to check out the stations online on the interactive map: http://raspberryshake.net/stationview/
jbeale
Raspberry Shake -update March 2018
Thu Mar 22, 2018 10:29 pm
After a year and a few months, my Raspberry Shake is continuing to operate well in my garage, sending a constant stream of seismic data to the online server. I have to say I have been impressed by the stability of this device. It has captured quite a few earthquakes (I'm in California) and has had no unexpected downtime that I know of. I work with a lot of homebrew projects and other commercial embedded devices, and I cannot say the same of any of them! The OSOP team in Panama that continues to develop the hardware and the global network has remotely updated the R-Shake several times during the past year, all hands-free on my end.
Just today, the same group launched a new kickstarter with a similar idea: this time called "Raspberry BOOM" which is an infrasound monitor. So it's like the previous "Shake" project, but using a microbarometer (air pressure sensor) instead of a geophone (ground vibration sensor).
One of my own motivations is that in my neighborhood we have an online forum "Nextdoor" and with some regularity I will see posts like "did anyone hear that sound just now, maybe a firecracker? ...or a gunshot?" And then a few more people will post who either did or didn't hear something, and someone else will say they hear that kind of sound all the time, and it's hard to say what the bump in the night was, if indeed it happened at all.
Now with something like this instrument, if you do pick up a signal you could say at least when it was, and quantitatively how loud compared with other such things previously observed, and from past records how often that type of sound happens. And if several neighbors had these and picked it up, (can you imagine, several neighbors, they might think it was a movement... oops, sorry) you might be able to tell something about where it came from, since NTP can keep the RPi clock aligned to UTC often within 10 msec or so, which is the time it takes sound to travel about 3.3 meters. The R-Shake is networked and I gather the R-Boom will be, so it may be possible for the remote server to determine the location of a sound, if enough sensors capture it. They are already doing this for earthquakes with the R-Shake network, however I gather in the case of the "Boom" device this capability is speculative and as yet untested.
I don't have this device yet but recently I played around inside with a regular microphone modified for lower frequency response and was interested to see I could tell when doors several rooms away open and close from the air movement, and when people walk over the wood floor which apparently flexes from the weight like a drumhead, causing low-frequency pressure fluctuations. My mic hack is only good to about 1 Hz but the "Boom" claims sensitivity down to 0.05 Hz which is a 20-second period.
Lower frequency sounds travel longer distances. One extreme example is the 2013 Chelyabinsk meteor which emitted pressure waves detected around the world by the existing infrasound network intended to monitor nuclear tests. Meteors that large are rare, but if (when) another one like that hits, there's a good chance this device could detect it. Likewise with large volcanic eruptions.
FWIW I am not affiliated with the group doing the kickstarter, but I think these widgets are very cool, so I wanted to post here.
cheers,
-John
jbeale
Sun Mar 25, 2018 5:46 am
Addendum: after a bit more research, I've come to the conclusion that an instrument like the "Raspberry Boom" which is detecting only sound below 40 Hz, is good for sensing events that move large volumes of air: meteors, volcanic eruptions, large-scale explosions, ocean surf, and of course wind. It should pick up things that go "whoosh" or "boom" better than your ear does, and from longer distances. However it detects much less than your ear does of smaller things that go "crack" or "bang", for example small fireworks, handguns, popping balloons, etc; those events show up mostly in the 200 Hz to 2 kHz range (and higher frequencies, when they are closer).
Return to “For sale”
Who is online
Users browsing this forum: No registered users and 2 guests
