alexeames
RasPiO Duino on Special This week
Wed May 04, 2016 9:11 am
RasPiO Duino promotion this week. £11 including global shipping (regular price £14).
http://rasp.io/duino
Includes Image
free 54 page guide to learning Arduino programming on the Raspberry Pi
Alex Eames RasPi.TV, RasP.iO
KenT
Re: RasPiO Duino on Special This week
Wed May 04, 2016 10:29 am
Think your 5 pack price may be wrong at £55 when 2 pack is £21
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
BMS Doug
Tue May 17, 2016 12:05 pm
I've got two of these and can recommend them, great device!
Doug.
shuckle
Tue May 17, 2016 12:35 pm
Tried to read those docs... I understand that it is possible to upload arduino sketches into this from Raspi. And then it works like normal Arduino.
But is it possible to discuss (change data) with Raspi and RasPiO? Connecting normal Arduino to Raspi is pretty trivial using USB, so it is possible to do measurements in Arduino and then get the results and process them in Raspi. Is it possible to do the same with this and how complex it is (there is no USB in the RasPiO board)?
BMS Doug
Tue May 17, 2016 12:50 pm
shuckle wrote:Tried to read those docs... I understand that it is possible to upload arduino sketches into this from Raspi. And then it works like normal Arduino.
you can connect via terminal by leaving the RX and TX jumpers connected, see page 41 onwards of the manual.
Alex Eames wrote:LDR_LED_serial
You may have noticed in the LDR_LED circuit diagram that I sneaked in two extra connections
unannounced. I'm talking about the Rx-Tx and Tx-Rx jumpers. You didn't actually need them for
the previous sketch, but you will for this one because they connect the serial ports of the ATMEGA
and the Pi so that they can communicate with each other.
Doug.
shuckle
Tue May 17, 2016 12:56 pm
Thanks, Doug!
Looks good, indeed.
BMS Doug
Tue May 17, 2016 1:02 pm
You could also look at the google+ group
Doug.
Return to “For sale”
