zocko
Case cooling
Sat Jul 07, 2012 9:54 pm
Good Day All - I see a number of great cases for sale with some vendors offering setups for a cooling fan. Does the Pi produce enough heat to warrant a fan? I want to take mine when I travel to tinker with and feel a fan on the outside might get banged up. Thoughts? Thanks!
Zocko
walleee
Re: Case cooling
Sun Jul 08, 2012 1:45 pm
I think the fact that it sells without one confirms you don't need one.
zocko
Re: Case cooling
Sun Jul 08, 2012 10:39 pm
Good Point - Thanks Walleee!
Zocko
locodoc
Re: Case cooling
Tue Jul 10, 2012 1:20 pm
It sells with out a case... ...maybe it does not need a fan
IF it is not enclosed ?
thexman
Re: Case cooling
Tue Jul 10, 2012 5:05 pm
ive been running all three Pi's i own one running XBMC is the warmest at just over 40DegC the other's running Wheezy doesn't and the Arch doesn't either so dont know what all the fuss is Even Eban upton said its gets a little over body temperature so stop worrying about cooling.
one armed controls engineer, my grammar is bad but lets face it most keyboards don't suit a one armed man
eLJay
Re: Case cooling
Mon Oct 01, 2012 2:59 pm
Only of you clock it as high as it will go might you even need to consider a fan.
Personally I'm waiting for some cheap heatsinks to arrive from Taiwan and then I'll give passive cooling a try for overclocking.
Lob0426
Re: Case cooling
Tue Oct 02, 2012 4:04 am
With a case and a mild overclock you will have no problems at all. Even at 1GHz most people are not using heatsinks. Buy a case you like and do not worry about it.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
nhslzt
Re: Case cooling
Tue Oct 02, 2012 7:29 pm
For a nice set of 3 heatsinks and peace of mind head over to
http://www.etsy.com/shop/nhslzt
heatsink set.jpg (29.24 KiB) Viewed 2845 times
Return to “For sale”
