SALE: Many unused RPi Model B in UK
Posted: Thu Mar 12, 2015 11:42 am
by PiModelB
THESE ARE ALL GONE NOW.
These are Model B, they are brand new and here in the UK, some are in the pink plastic boxes from RS, others in Element14 cardboard boxes.
( They are NOT Raspberry Pi 2 Model B or Raspberry Pi 1 Model B+ )
These are just the boards, so do not include any of these items : SD cards / power supply / cables.
If you are interested, send me a PM through the forum and let me know how many you need.
Re: SALE: Many unused RPi Model B in UK
Posted: Thu Mar 12, 2015 12:08 pm
by RaTTuS
how much are you selling them for
Posted: Thu Mar 12, 2015 12:31 pm
by PiModelB
RaTTuS wrote:how much are you selling them for
That would depend on how many you'd like - PM me an offer !
Posted: Thu Mar 12, 2015 2:01 pm
by plugwash
You might want to specify what exactly it is you are selling. rev1 with polyfuses? rev1 with zero ohm links? rev2 256MB? rev2 512MB? rev2.1?
Posted: Thu Mar 12, 2015 3:22 pm
by PiModelB
plugwash wrote:You might want to specify what exactly it is you are selling. rev1 with polyfuses? rev1 with zero ohm links? rev2 256MB? rev2 512MB? rev2.1?
I believe that they are all Revision 2 512MB (they arrived Apr 2013).
Of the Element 14 ones that I've opened the cardboard boxes for (the first time), these all have mounting holes and the additional 2x4 header alongside the 26pin GPIO port and say made in the UK- so I believe that these are all rev 2 512 MB.
Of the RS ones, on the yellow stickers on the pink boxes it says "Raspberry Pi B" and "Made in China".
Is it possible to identify them from any of the other numbers e.g. 756-8308 on the yellow stickers without breaking the seal ?
Of the RS ones, I've opened one, it has mounting holes, confirms "made in china", has a Black audio port, no black 'Christmas tree' on the USB port, does have "HanRun HR090110A 1247" on the Ethernet port and looks like what this site calls a Raspberry Pi 512MB Model, board revision 3.
Hope that helps & if the moderators or anyone in the know can confirm anything more, I'll update the original post.
Posted: Thu Mar 12, 2015 3:30 pm
by DougieLawson
If you booted one you could look at /proc/cpuinfo or /proc/cmdline and it gives an absolutely positive indication of which model of Raspberry Pi you've got.
[email protected]:~# cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 2.00
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 00000000hhhhhhhh
[email protected]:~# cat /proc/cmdline
dma.dmachans=0x7f35 bcm2708_fb.fbwidth=592 bcm2708_fb.fbheight=448 bcm2708.boardrev=0xe bcm2708.serial=0xhhhhhhhh smsc95xx.macaddr=B8:27:EB:hh:hh:hh bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
Posted: Thu Mar 12, 2015 3:41 pm
by PiModelB
DougieLawson wrote:If you booted one you could look at ..........
Thanks, Yes once booted up it's easy - but then I wouldn't be able to sell them as "NEW" !
( I also don't want to do this 'n' times .... )
Posted: Thu Mar 12, 2015 3:46 pm
by DougieLawson
The P5 header is the best clue. My original B (October 2012) doesn't have that. My later (2013) Bs all do have it.
Posted: Thu Mar 12, 2015 4:04 pm
by PiModelB
DougieLawson wrote:The P5 header is the best clue. My original B (October 2012) doesn't have that. My later (2013) Bs all do have it.
Yes, that header was what I meant by : "additional 2x4 header alongside the 26pin GPIO port".
All I'm really after is whether it is possible to identify the pink boxed RS ones WITHOUT opening all of the boxes or powering them all up (by any of the markings on the pink case :either the 756-8308, CB19 or N13019).
Posted: Thu Mar 12, 2015 4:05 pm
by plugwash
I think they changed the code when they moved to 512MB so I think the fact they have a current model B product code on them means they are 512MB models.
Posted: Thu Mar 12, 2015 4:11 pm
by PiModelB
plugwash wrote:I think they changed the code when they moved to 512MB so I think the fact they have a current model B product code on them means they are 512MB models.
plugwash many thanks, that's the kind of confirmation that I'm after !
Any takers ?
Posted: Thu Mar 12, 2015 4:17 pm
by mikerr
Please supply numbers - do you have 5,10,100,1000 for sale ?
Posted: Thu Mar 12, 2015 4:23 pm
by DougieLawson
I didn't think there'd ever been a 256MB model with the P5 header.
Time to refer to Alex Eames' family photo.
Posted: Thu Mar 12, 2015 4:28 pm
by PiModelB
mikerr wrote:Please supply numbers - do you have 5,10,100,1000 for sale ?
Mike, yes something like that, do you actually want any ?
Posted: Thu Mar 12, 2015 5:07 pm
by PiModelB
DougieLawson wrote:...I didn't think there'd ever been a 256MB model with the P5 header.....
Thanks Dougie, hadn't seen that pic before.
Posted: Sat Mar 14, 2015 7:03 pm
by pi-anazazi
Posted: Sat Mar 14, 2015 10:06 pm
by BMS Doug
They wouldn't fit the "unused" description, also I would imagine that they would still be needed to serve their designed purpose.
Posted: Thu Mar 19, 2015 3:17 pm
by cptdodgerm
Does not instill buying confidence when perfectly reasonable questions about the sale are asked but the replies back are very cagey and will only communicate via PM if direct answers are required. This one has 'walk away' all over it.
Posted: Tue Apr 07, 2015 8:23 pm
by Elfen
I and the group I'm in would require several - NYLXS (New York Linux Scene - http://nylxs.org/ ) - to start a class on Linux and The Raspberry Pi with K-12 students. Do you still have any more? I'm posting here as for some reason PM Link does not work on Safari 4.1.8 on Mac OSX 10.4. I would need to discuss this with NYLXS as to the exact number needed but I know that its more than 10. We already got a few, but the need is greater. Plus I'm in NYC, NY, USA, across the "Great Pond."
~Elfen
Posted: Tue Apr 07, 2015 9:46 pm
by DirkS
Elfen wrote:I'm posting here as for some reason PM Link does not work
You can only send a PM after you have posted once. So it should work now.
Posted: Thu Apr 09, 2015 5:35 pm
by Elfen
Thank DirkS. I'll send a PM to the original poster.
Posted: Fri Apr 10, 2015 12:40 pm
by PiModelB
I've had a few enquires but should have said that I'm only shipping to the UK.
As far as the comment :
cptdodgerm wrote:Does not instill buying confidence when perfectly reasonable questions about the sale are asked but the replies back are very cagey and will only communicate via PM if direct answers are required. This one has 'walk away' all over it.
You're entitled to your opinion.
I have some left but what I'd sell one for is different to what I'd sell 100 for - unreasonable ?
( Also depending on whether suppliers state that they have 1,100 in stock or none until 22 September 2015 !
Thanks to the other forum members for your help / suggestions / Links.
Posted: Tue May 05, 2015 11:34 am
by Jonovich
Just found that my old 256Mb Pi's do not have enough memory for the latest MotionPie build, so need to think about replacing them. If you have a couple of 512Mb B's, would you take 30 quid for them?
Cheers,
Jon.
