tinylcd
3.5'' TFT Display (320x480 pixels) for Raspberry Pi B+/ Pi 2
Fri Feb 20, 2015 1:18 pm
Now we are ready for 3.5 inch TFT/lcd/display having 320x480 pixels for Raspberry Pi B+ / Pi 2
with touch screen and/or navigation keys and or/ RTC .
40 pin Breakout board for additional use of rest GPIO pins.
Products are
3.5'' Display only
http://www.neosecsolutions.com//product ... 2&cPath=20
3.5'' Display with Touch Screen
http://www.neosecsolutions.com//product ... 7&cPath=20
3.5'' TFT Display + Touch Screen + separate Navigation Keys + RTC
http://www.neosecsolutions.com//product ... 0&cPath=20
3.5'' TFT Display + Touch Screen & RTC
http://www.neosecsolutions.com//product ... 8&cPath=20
http://www.neosecsolutions.com//product ... 9&cPath=20
By default images are provided on DVD for above options.
Optionally one can buy sd card with images preloaded for above options.
Regards
neosecsolutions
Re: 3.5'' TFT Display (320x480 pixels) for Raspberry Pi B+/
Fri Feb 20, 2015 4:08 pm
Does it work on an A+?
This is a doctor free zone.
AndyD
Sat Feb 21, 2015 2:51 am
DougieLawson wrote:Does it work on an A+?
I can't imagine why they wouldn't work on an A+, there is no difference in the pin-out of the GPIO between the B+ and the A+ (as far as I know). Perhaps this is a rhetorical question?
I have one of the older (26 pin header) Neosec "3.5 display only" on a Raspberry Pi Model A and I am very happy with it. Works well with Notro's fbtft.
tinylcd
Sat Feb 21, 2015 5:12 am
Hello
neosec tft display and touch use spi signals
in A+ and B+ / Pi2 the spi signals are at the same pin number on the connector
so same pcb can be used
But the GPIO number used for these spi are different in A+ and B+/Pi2
the advantage of new image is that these GPIOs are now configurable
we give full credit to Notro for this wonderful job done by him
so theoretically it should work on A+
since we have not yet tested on A+ we have not mentioned A+ in our post
once we test it on A+ we will mention same on our post
regards
tinylcd
tinylcd
3.5'' TFT Display (320x480 pixels) for Raspberry Pi A+/B+/Pi
Tue Feb 24, 2015 5:14 am
Hello
we have tested our display touch RTC and navigation keys
they are all working on our same PCB on Raspberry Pi A+ /B+ and Pi 2
regards
tinylcd
Forgotten01
Mon Mar 30, 2015 11:11 pm
Do they come without the breakout board for sing more gpio pins, I don't need to use the gpio for anything besides the screen
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
Scott Adams
tinylcd
Tue Mar 31, 2015 4:43 am
hello
the breakout board is designed in such a way that it can be easily detached by applying slight pressure
similar to the perforated paper for easy tearing
we can also ship it without the breakout board
regards
tinylcd
fanoush
Tue Mar 31, 2015 7:24 pm
Do you plan to make displays using DPI interface instead of SPI for A+/B+/Pi2? This is not DSI but DPI as described here
http://blog.reasonablycorrect.com/raw-dpi-raspberry-pi/ The advantage is speed and full 3D acceleration for lower price (?) when compared to HDMI based solution.
tinylcd
Wed Apr 01, 2015 10:15 am
Hello
there may be a better speed with DPI
but than major GPIO are exhausted and for price we think HDMI with higher resolution will be still cost effective compare to price indication given in your blog link
you can visit below link for our 7 inch HDMI series to get price indication
http://www.neosecsolutions.com//index.p ... c71adc2b85
regards
tinylcd
solar3000
Sun Apr 12, 2015 10:41 am
is this on ebay or amazon or newegg?
Antikythera
tinylcd
Sun Apr 12, 2015 2:09 pm
Hello
No. it is not available on ebay/amazon
It is available online at following website
regards
tinylcd
peepo
Thu May 21, 2015 8:02 am
do you have similar 640x480 SPI display in production?
tinylcd
Thu May 21, 2015 1:45 pm
Soon we will be launch in 4 inch with 800x480 pixels
With SPI interface
Regards
Tinylcd
peepo
Fri May 22, 2015 3:17 pm
excellent news, please advise when shipping
Do any of your displays have an 8-bit interface?
https://www.adafruit.com/products/2050
tinylcd
Mon May 25, 2015 10:10 pm
Hello
Fbc is pending
Will update you once shipping is started.
We do not have tft with 8 bit interface
But we do have 7 inch high resolution with HDMI interface
Regards
Tinylcd
afrog2
Mon Jun 08, 2015 12:04 pm
I have ordered 1 3.5 inch TFT display (http://www.neosecsolutions.com//product ... 8&cPath=17).
Do you have an update compiled image for this product? The one provided is very dated and all instructions in regard to building a new image are out-of-date as some repos have moved or are no longer supported.
If you have new image or new instructions for building new image with updated repo, this would be great!
Also, Do you have a case available? Trying to avoid customizing a case.
Thanks.
tinylcd
Tue Jun 09, 2015 1:58 am
Hello
We do have latest updated image . mail us your order details so se can send you appropriate details.
We do not have case for 3.5. But we do have a case for 7 inch
Regards
Tinylcd
AndyD
Tue Jun 09, 2015 4:36 am
afrog2 wrote:Hi,
Thanks.
I have that display. It is actually supported in the kernel that is supplied with Raspbian, as long as it is reasonably up-to-date. Just add the following to config.txt
dtoverlay=tinylcd35
afrog2
Wed Jun 10, 2015 4:01 am
AndyD wrote:
afrog2 wrote:Hi,
Thanks.
dtoverlay=tinylcd35
Thank you AndyD! Will give this a shot.
tinylcd wrote:Hello
Regards
Tinylcd
I will try the latest raspberian build first, thank you :)
AndyD
Wed Jun 10, 2015 4:51 am
afrog2 wrote:Thank you AndyD! Will give this a shot.
HI afrog2, sorry just realized that I probably haven't given you enough information. If you want the Desktop on your TFT display and/or if you want the boot messages to be displayed on your TFT display it will take a little bit more to set it up.
So first add the following to config.txt
dtoverlay=tinylcd35
you may want to rotate the display (as the display is 320x480 rather than 480x320). I use:
dtoverlay=tinylcd35,rotate=270
Now reboot.
If you want the boot messages to appear follow these instructions on Notro's wiki.
To start the desktop on the TFT, follow the instructions from here.
Return to “For sale”
