Hi all,
Does anyone know if PIGPIO runs on the latest raspian. I am using a model B+ (not a 2) and have had pigpio running quite happily. I have now upgraded to the 31-01-2015 release of Raspian and I get the following error when trying to run my program:
Can't connect to pigpio on localhost(8888)
Did you start the pigpio daemon? E.g. sudo pigpiod
Did you specify the correct Pi host/port in the environment
variables PIGPIO_ADDR/PIGPIO_PORT?
E.g. export PIGPIO_ADDR=soft, export PIGPIO_PORT=8888
pigpio.pi() function? E.g. pigpio.pi('soft', 8888))
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_CharLCD/IR_bit_bash_v1.1.py", line 13, in <module>
from IR_hashread_V1 import gather # The IR_hashread.py script interfaces with the pigpiod deamon. The gather() function returns any received IR pulses. See IR_hashreah.py for more information
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_CharLCD/IR_hashread_V1.py", line 46, in <module>
ir = ir_hasher.hasher(pi, 21, callback, 5) # Set the GPIO pin as an instance of the 'hasher' class. See the 'IR_hasher.py' script for the class details.
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_CharLCD/ir_hasher.py", line 31, in __init__
pi.set_mode(gpio, pigpio.INPUT) # Initialises a GPIO pin of the RPi as an input.
File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 945, in set_mode
return _u2i(_pigpio_command(self.sl, _PI_CMD_MODES, gpio, mode))
File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 753, in _pigpio_command
sl.s.send(struct.pack('IIII', cmd, p1, p2, 0))
AttributeError: 'NoneType' object has no attribute 'send'
I have tried typing in the terminal:
sudo pigpiod
to start the deamon before running my program but same result.
I have changed my program from:
pigpio.pi()
to:
with no avail.
Any thoughts?
