The German
Access GPIO from multiple instances?
Sun Feb 08, 2015 10:01 pm
I am running a shell with a python script that is monitoring a physical button
GPIO.setmode(GPIO.BOARD)
GPIO.setup(37, GPIO.IN, pull_up_down = GPIO.PUD_DOWN)
GPIO.add_event_detect(37, GPIO.RISING, callback=MenuButton, bouncetime=300)
That works just fine and the MenuButton function is being called when the button gets pressed and released.
Now, for testing purposes, I want to trigger the RISING event from the outside our of another shell / script. The problem is that the GPIO port seems to be exclusive to a single script running, or?
Any thoughts how to get this done are greatly appreciated!
joan
Re: Access GPIO from multiple instances?
Sun Feb 08, 2015 11:33 pm
Couldn't you just connect another gpio to the switch gpio? To trigger the rising edge set the other gpio as an output and write 1. Probably best to put a 10k or so resistor in series with the triggering gpio.
