Voltage question
Posted: Sun Feb 08, 2015 7:13 pm
Hello all,
i have a wind sensor (TX23 from lacrosse) connected to my py, and OFTEN it works. I mean than when raspi boots up, it do not work, if i disconnect and reconnect the cable, it starts working and never stops.
This happens only when i take off the power to the raspi, if i restart it the sensor always works.
It is commonly powered by 2 AAA batteries (3V). I powered it up with 3,3V from Raspi.
Now, since it's an annoyin problem, i powered it with a couple of batteries (common ground with raspi, obviously).
Magically, now it always work.
So i thought that maybe the way power line goes up can create the problem. But what if i'd like to avoid batterie? what can i use?
Or better, what about something like this
In my idea, this is giving solid minimum 3V to the sensor, and current on the resistor should be very low. But with this circuit, who is powering the sensor?
Can this work?
thanks a lot
raspi 3,3V
big resistor, let's say 1M
Sensor VCC and batteries +
common ground
Can this work?
thanks a lot
