standin000
how to fsck FAT-fs in raspbian[RESOLVED]
Sun Jan 25, 2015 3:19 am
Because raspberry shutdown suddenly sometime, it reports
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
I have to plug out SD card and put it into sd card reader with a PC for running fsck.
I tried fsck in raspbian with different parameter to fix this disk, but it failed.
Is there a software package can fix corrupt fat fs? thanks in advance.
rpdom
Re: how to fsck FAT-fs in raspbian
Sun Jan 25, 2015 6:44 pm
The latest version (3.0.13-1+rpi1) of dosfstools in Raspbian should be able to fix it with fsck.vfat -r
standin000
Mon Jan 26, 2015 1:18 pm
rpdom wrote:The latest version (3.0.13-1+rpi1) of dosfstools in Raspbian should be able to fix it with fsck.vfat -r
after updating to 3.0.13-1+rpi1, it is OK now , thanks very much!
Raspruss
Mon Feb 23, 2015 12:31 pm
My daughter power-cycled my Pi a couple times fairly rapidly via the outlet strip (wrong one of two!) and now I get the same error as noted in the first post of this thread. My Pi successfully boots and all seems well, but I think it's much better to not have a boot error...
Does dosfstools work on a mounted /boot right from a post-logn prompt?
[I =can= go to the trouble of creating a new SD card from an "old" image backup, use THAT to start up Raspbian, then use fsck with that to fix the boot of the unmounted primary SD card but, if dosfstools works as desired, it would be much faster]
jojopi
Mon Feb 23, 2015 1:36 pm
Raspruss wrote:Does dosfstools work on a mounted /boot right from a post-logn prompt?
Do not run fsck on a filesystem while it is mounted read-write. Just unmount it first. Raspbian only actually needs /boot mounted during firmware updates etc.
sudo apt-get update
sudo apt-get install dosfstools
sudo umount /boot
sudo fsck -a /boot
sudo mount /boot
Even this should not be necessary, though. Once you have dosfstools up to date, the init scripts will run fsck at the next boot.
Raspruss
Mon Feb 23, 2015 2:23 pm
Cool, I'll be trying that soon - thanks.
Raspruss
Mon Feb 23, 2015 2:59 pm
Thanks again, jojopi, that did indeed work fine and all is again well filesystem-wise...and I've shown my daughter which power strip is the one to use...
Return to “Beginners”
