sprudeldude
HDD
Thu Jan 22, 2015 8:58 pm
When i plug my HDD Seagate 2TB with no external supply into my pi, and i perform a fdisk -l.
The HDD doesn't show up and i hear that my HDD sounds like it is keep restarting.
What is the problem ?
Grt
B.Goode
Re: HDD
Thu Jan 22, 2015 9:00 pm
It is not receiving enough power via the usb connection to function correctly.
sprudeldude
Re: HDD
Thu Jan 22, 2015 9:15 pm
B.Goode wrote:It is not receiving enough power via the usb connection to function correctly.
How is that ?
Because my adapter supplies 2A, so the usb connections must have enough to supply my HDD ?
gkreidl
Re: HDD
Thu Jan 22, 2015 9:25 pm
On a B it cannot work.
On a B+ you have to add
max_usb_current=1
to config.txt.
Minimal Kiosk Browser (kweb)
sprudeldude
Re: HDD
Thu Jan 22, 2015 9:27 pm
gkreidl wrote:On a B it cannot work.
max_usb_current=1
to config.txt.
I have a B+ model.
So if i change the config.txt, i can see my HDD in fdisk -l ?
Re: HDD
Thu Jan 22, 2015 9:33 pm
max_usb_current=1
to config.txt.
I have a B+ model.
2.5" USB Drive likely, 3.5" USB Drive unlikely
https://projects.drogon.net/testing-set ... berry-pi-b
RPi 4B 4GB (SSD Boot)..
gkreidl
Re: HDD
Thu Jan 22, 2015 9:34 pm
max_usb_current=1
to config.txt.
I have a B+ model.
At least it will make sure, that the USB ports get 1.2 A (all of them together). I'm running my B+ from HDD (root FS) this way. But it depends on the quality of your power supply (including cable) and on other hardware connected to the USB ports.
gkreidl
Re: HDD
Thu Jan 22, 2015 9:36 pm
fruitoftheloom wrote: 2.5" USB Drive likely, 3.5" USB Drive unlikely
3.5 " drives always have their own power supply (at least for 12V); Many newer ones take the 5V from USB, though, but that shouldn't be a problem for a B+.
sprudeldude
Re: HDD
Fri Jan 23, 2015 12:11 pm
Everthing worked after changing the config.txt thanks to gkreidl !
