All,
I have 2 Model B+ Pis
I have been trying to clone the SD card from Pi 1 so I can get my second Pi up and running exactly as my first one.
I used Win32DiskImager as suggested on several Pi forums. I imaged my Pi # 1 SD card, then laid that image onto Card #2. But when I booted Pi # 2 it had errors and would not boot.
I tried this several times to no avail.
Is there a good way to clone the SD card, including all the partitions ? I want to do this for error recovery purposes too.
Thanks Much.
Don
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: Clone or backup FULL SD Card
Use a Raspberry Pi with a USB SDCard reader. You can copy the card you're booted from that way.
sudo dd if=/dev/mmcblk0 of=/dev/sdb bs=30M &
Use a Raspberry Pi with two USB SDCard readers and copy can copy one inactive card to another that way.
sudo dd if=/dev/sdb of=/dev/sdc bs=30M &
If you want to reformat SDCards to blank (as if they are factory fresh), use a camera or an Android tablet.
Format the card with SDFormatter with the size option. Then use Win32DiskImager to read the first card then write the second card.
I have never had a problem "cloning" a card this way.
Try a different card as the second may be messed up.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
Strange. I must have done something wrong.
I ended up using my MAC in the terminal mode using dd
Thanks for the fast replies!
Don
Don
is this also possible when the original sd-card is 32Gb (only 6GB in use) and the new card is 16Gb..
No, the image will be the size of the original SD cardikke4 wrote:is this also possible when the original sd-card is 32Gb (only 6GB in use) and the new card is 16Gb..
It is possible to shrink it after creating the image with scripts / programs like Image Shrinker (see http://www.raspberrypi.org/forums/viewt ... p?p=656640)
thanks, i'll look into it...
- DougieLawson
That only works if you skip the even numbered bytesikke4 wrote:is this also possible when the original sd-card is 32Gb (only 6GB in use) and the new card is 16Gb..
thanks,
i did what you suggested and throwed away all the "zero's"! it really works great, not only do i have a very small partition, booting speed has increased with a factor 2..
thank you
thank you
