monkeymademe
GPIO Buttons in Adventures in Raspberry Pi not working
Fri Jan 09, 2015 12:50 pm
I am on the chapter making the jukebox and I hit a little road block.
I have everything wired up and triple checked the code but the buttons don't seem to work. As far as I can see everything is perfect?! am I missing something?
BMS Doug
Re: GPIO Buttons in Adventures in Raspberry Pi not working
Fri Jan 09, 2015 1:00 pm
monkeymademe wrote:I am on the chapter making the jukebox and I hit a little road block.
do you have a link to a high resolution image?
The https://pbs.twimg.com/media/B66MVRcCQAEwvwt.jpg:large image doesn't zoom in well so I can't make out the details.
Doug.
Richard-TX
Fri Jan 09, 2015 2:53 pm
rotate the push buttons 90 degrees
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
