Evilbadger
Re: Commented Config.txt
Sat Aug 11, 2012 9:17 pm
New version available here:
https://github.com/Evilpaul/RPi-config
- trim line lengths to a max of 80 chars
- add basic user description
Raw file can be accessed here:
https://raw.github.com/Evilpaul/RPi-con ... config.txt
Evilbadger
Fri Aug 17, 2012 7:42 pm
- addition of edid_format_smart_match
- addition of hdmi_ignore_cec_init
- Description change for hdmi_ignore_cec
- Correct the values for hdmi_ignore_cec
Evilbadger
Sat Aug 18, 2012 12:47 pm
- addition of avoid_pwm_pll
Evilbadger
Fri Aug 24, 2012 8:18 pm
- addition of Licensed Codecs section
Evilbadger
Sat Sep 01, 2012 2:49 pm
- addition of display_rotate option
Evilbadger
Mon Sep 17, 2012 4:08 pm
  • Minor grammar fix in some option descriptions
  • Add plain description of the default for init_uart_clock
  • add default value description for boot_delay
  • addition of boot_delay_ms
  • addition of dynamic clock options (force_turbo, arm_freq_min, core_freq_min, sdram_freq_min, over_voltage_min)
  • Update Overclocking section header to reflect latest firmware frequency calculations
  • addition of temp_limit and description of over-temperature safeguards
Evilbadger
Fri Sep 21, 2012 6:08 pm
  • modify statement about overclock temperature limit to always be true
  • removed detailed HDMI format instructions
  • add statement describing multiple per CODEC licenses
  • addition of current_limit_override option
  • addition of hdmi_edid_file option
  • replace edid_format_smart_match with avoid_edid_fuzzy_match
  • update and relocate warning about voiding the warranty
  • move over-temperature statement to a more relevent place and prevent repeated information
  • add table of standard overclock profiles
Evilbadger
Mon Sep 24, 2012 8:11 pm
  • addition of initial_turbo option
Evilbadger
Mon Oct 22, 2012 5:07 pm
  • update default init_emmc_clock value
  • addition of gpu_mem, gpu_mem_256 and gpu_mem_512 options
Evilbadger
Sun Jun 16, 2013 9:15 pm
  • additional display_rotate values and description
  • Update wiki location
  • modify description of enabling hdmi_safe
  • modify description of avoid_pwm_pll
  • modify overclocking options and warrenty warning
  • add option disable_pvt
  • add CMA options
  • add cmdline.txt requirment for CMA
  • add option hdmi_force_edid_3d
  • add option hdmi_pixel_encoding
  • add option kernel_old
Evilbadger
Sat Jun 22, 2013 6:45 pm
  • add option hdmi_ignore_edid_audio
  • add option disable_camera_led
  • add option disable_splash
Return to “Beginners”
