physicsllama
security and new accounts
Sun Dec 28, 2014 10:20 pm
I recently got a new pi B+ and eventually I want to run a file server. I'm just learning linux UI and I want to switch over to a new account from the default for security. I created a new account and gave it passwordless sudo access. However, it still asks for a password. Additionally it seems that this new account still has limited permission. Are there further changes I should make? In its desktop gui the shutdown icon is missing or hidden, and while I am fine using the console it is easier to use once I've started the gui.
Richard-TX
Re: security and new accounts
Mon Dec 29, 2014 3:27 am
If you want it secure, then don't use sudo. Assign a root password and use su.
Sudo is a security risk. I work at a large financial institution and few things will get you fired faster than installing sudo, sus, etc.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
