raspskrw
APPUSB150NANO
Fri Dec 19, 2014 8:25 pm
Hello family,
I'm starting in debian / raspberry and have a little problem.
I bought the wifi Blast APPUSB150NANO to my raspberry with Raspbian and I can not configure the wifi.
when I do a lsusb I detected: Bus 001 Device 004: ID148f: 7601 Ralink Technology Corp, but the WIFI Setting Raspbian software did not detect anything ...
In the manual puts Blast leading REALTEK USB chipset but does not say which. It also makes it coompatible with Rasberry Pi
They know about it?
Gomez
Re: APPUSB150NANO
Sat Dec 20, 2014 6:21 am
If it is not working properly with the system but it has built-in drivers plus your raspberry is detecting it then you should be fine with the following links, they can guide you in how to configure wifi manually.
http://raspberrypihq.com/how-to-add-wif ... pberry-pi/
or
http://weworkweplay.com/play/automatica ... i-network/
If it doesn't have built-in drivers which my also be the issue, try this :
http://raspberrypi.stackexchange.com/qu ... t-detected
That is all I can help, I use ethernet so if you still can't connect with wifi after these links then wait for someone more experienced to reply on this topic.
Good luck.
pluggy
Re: APPUSB150NANO
Sat Dec 20, 2014 8:53 am
It doesn't work with the Pi out of the box, thread here discussing the same chipset http://www.raspberrypi.org/forums/viewt ... 28&t=73298 Mr Engman has drivers for it but it takes a lot of work.
raspskrw
Re: APPUSB150NANO
Sat Dec 20, 2014 8:52 pm
when I put pi@raspberrypi ~ $ sudo update-usbids like the link the pluggy
and after setting the file /etc/network/interfaces
worked OK
many thanks
