tadd
GPIO from command line
Wed Dec 17, 2014 5:21 am
I am trying to do the first thing with GPIOs, that is, turning one on.
It seems I'm missing something or I skipped a lesson. What do I have to do to get the gpio command to work from the command line, bash, logged in a terminal?
When I type
gpio
I get
-bash: gpio: command not found
There is no manpage for gpio.
I'm using Debian Wheezy on a Raspberry PI B
Re: GPIO from command line
Wed Dec 17, 2014 6:28 am
You'll need to install the Wiring Pi utilities from http://wiringpi.com/
There are full instructions on how to download and install them on that site.
aTao
Wed Dec 17, 2014 6:37 am
You dont even need "gpio" package. The RPi GPIOs can be accessed as files. Have a look at https://sites.google.com/site/semillero ... rials/gpio
pluggy
Wed Dec 17, 2014 6:08 pm
If you want the gpio command to work then you need wiringpi, but you can manipulate it using files as has been said.
example bash script using nothing but the built in software to flash an led connected to gpio 9 :
#!/bin/bash
echo 9 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio9/direction
while [[ : ]]
  do
    echo 1 > /sys/class/gpio/gpio9/value
    sleep 1
    echo 0 > /sys/class/gpio/gpio9/value
    sleep 1
done
