mak46
gpio 5,6,12,13, etc
Sun Dec 07, 2014 8:57 am
Raspberry Pi B+ , Debian , ScratchGPIO5 & 5plus , how can I use pins above 28 . I used/tested already pins up to 26 but above 28 , I cannot access . thank you in advance . mak46
joan
Re: gpio 5,6,12,13, etc
Sun Dec 07, 2014 9:35 am
Is this a problem using scratch? Or is it a problem using all software?
On the B+ gpios 0-27 are available on the expansion header (there is no case where gpioX is on pinX of the expansion header).
B.Goode
Sun Dec 07, 2014 9:53 am
From a quick glance at the ScratchGPIO code on its github repository I am pretty certain that ScratchGPIO5 only supports board-numbered pins up to #26 for use with the original models A and B.
The author has a beta version of ScratchGPIO6 which supports pins up to #40, which would be compatible with the A+ and B+ models.
http://simplesi.net/scratchgpio-development-testing/
mak46
Sun Dec 07, 2014 11:33 am
joan wrote:Is this a problem using scratch? Or is it a problem using all software?
thank you joan , problem solved , best regards
mak46
Sun Dec 07, 2014 11:35 am
B.Goode wrote:From a quick glance at the ScratchGPIO code on its github repository I am pretty certain that ScratchGPIO5 only supports board-numbered pins up to #26 for use with the original models A and B.
thank you B.Goode , i used scratchgpio6 as you suggested , problem solved , everything works OK , best regards
mak46
