NMEA GPS Info (USB/Serial) via Python 2.x
Posted: Wed Nov 19, 2014 9:55 pm
by fsoguy
I have a few days off work and was bored so I decided to look into receiving data from my Pharos GPS-500. It only took a little while and now I seem to have the basics down. I've seen a few posts around that ask how to interface with a GPS, and there are several possible solutions. This one seemed the easiest to me. The first thing I did was plug in my GPS-500 and write a quick script to see if I was getting data. After that I decided to try and find a way to decipher the NMEA sentences. Google showed me the way. Here's how I am doing it using Python 2.x. P.S. Kudos to red_mamba who wrote these python modules: pyRestDb and pyNmea-RaspberryPi. I did not search for rmamba until after I posted this, where I came across his other GPS work. Fun stuff indeed.
This python script will show each character received, simply to prove that the GPS device is outputting data:
#!/usr/bin/env python
import sys
import serial
def init():
	ser = serial.Serial()
	ser.baudrate = 4800
	ser.port = '/dev/ttyUSB0'
	ser.open()
	if not ser.isOpen():
		print("Unable to open serial port!")
		raise SystemExit
	while True:
		gps = ser.read(1)
		print gps
try:
	init()
except KeyboardInterrupt:
	print "Done."
Here's the type of output you should see:
G
P
G
G
A
1
9
1
If you see random characters such as below then your baud rate is probably wrong.
à
f
x
ø
x
I believe these are the only prerequisites other than Python 2.x:
python-serial, python-flask, python-requests, pyRestDb, pyNmea-RaspberryPi
sudo apt-get install python-serial
sudo apt-get install python-flask
sudo apt-get install python-requests
sudo mkdir pyrestdb
cd pyrestdb
sudo wget https://github.com/rmamba/pyRestDb/archive/master.zip
sudo unzip master.zip
cd ..
sudo mkdir pynmea
cd pynmea
sudo wget https://github.com/rmamba/pyNmea-RaspberryPi/archive/master.zip
Now we have subfolders for each package and they are unzipped and ready to run.
I used 2 terminal windows for the next part.
Run the pyrestdb module in 1st terminal:
sudo python /path-to-pyrestdb/pyRestDb.py
Now in the pyrestdb terminal, you should see:
* Running on http://0.0.0.0:666/
Run the pynmea gpsd module in 2nd terminal:
sudo python /path-to-pynmea/gpsd.py start
Once you start the gpsy.py script, you will see the output from the pyrestdb terminal refreshing every second like this:
127.0.0.1 - - [19/Nov/2014 15:00:32] "POST /post/GPS HTTP/1.1" 200 -
127.0.0.1 - - [19/Nov/2014 15:00:34] "POST /post/GPS HTTP/1.1" 200 -
127.0.0.1 - - [19/Nov/2014 15:00:35] "POST /post/GPS HTTP/1.1" 200 -
This means that the data is being sent and the summary is served up at http://raspberry-Pi-IP-Add:666
If you visit http://raspberry-Pi-IP-Add:666 you will see a summary page of the GPS output,with all kinds of info including a Google maps link to your current location, satellites tracked, lat, long, speed, etc.
To be able to query specific info, you can use this schema:
Which will output a page to your browser that only contains the # of satellites tracked.
To check other info, just use the output page or documentation to figure out what it's called. Here's a short list of examples:
I don't have a project to apply this to right now, but as you can see the data is right there ready to be queried at the specific links.
This python solution uses about 13% CPU on my stock B+ Pi.
Re: NMEA GPS Info (USB/Serial) via Python 2.x
Posted: Thu Nov 27, 2014 6:19 am
by gauravsharma0190
hello sir
i am using wiring pi library for serial comm.
but itdidnt work .
then i moved to python...
when i used "import serial".....it tells no module
wht's is the problem and how to fix it.
Posted: Thu Nov 27, 2014 6:35 am
by gordon77
You probably need to install pyserial
Sudo apt-get install python-serial
Posted: Tue May 05, 2015 2:19 pm
by Carl_Panek
Has anyone gotten a NAVATION GPS 168 to work on an RPI under raspbian?
Posted: Tue May 05, 2015 4:06 pm
by Carl_Panek
Nope - other USB GPS receivers work just fine on my system.
Posted: Tue Nov 10, 2015 10:48 am
by red_mamba
fsoguy wrote:I have a few days off work and was bored so I decided to look into receiving data from my Pharos GPS-500. It only took a little while and now I seem to have the basics down. I've seen a few posts around that ask how to interface with a GPS, and there are several possible solutions. This one seemed the easiest to me. The first thing I did was plug in my GPS-500 and write a quick script to see if I was getting data. After that I decided to try and find a way to decipher the NMEA sentences. Google showed me the way. Here's how I am doing it using Python 2.x. P.S. Kudos to red_mamba who wrote these python modules: pyRestDb and pyNmea-RaspberryPi. I did not search for rmamba until after I posted this, where I came across his other GPS work. Fun stuff indeed.
import sys
import serial
def init():
	ser.baudrate = 4800
	ser.open()
		raise SystemExit
	while True:
		gps = ser.read(1)
		print gps
try:
	init()
	print "Done."
G
P
G
G
A
1
9
1
à
f
x
ø
x
sudo mkdir pyrestdb
cd pyrestdb
cd ..
sudo mkdir pynmea
cd pynmea
yay, I'm famous. Now if only the money would start flowing in :)
Good job! If anyone needs help with anything feel free to msg me.
I'm happy to help ppl out with advice and guidance ;)
Posted: Tue Nov 10, 2015 10:58 am
by scotty101
Of course gpsd is a much more robust solution that supports many different GPS receivers and there are many GUIs that can make use of its data.
Posted: Wed Mar 22, 2017 8:31 am
by venkyskar
What if the GPS has TTL connector and if I connect it to the GPIO will the above code be successful in reading the coordinates.
Posted: Wed Mar 22, 2017 5:18 pm
by red_mamba
serial TTL?
you can use cheap USB to TTL converter in that case and code should still work.
