Using the most recent Debian SD card image, I’ve booted up with the external drive attached to the second USB port
1.Logged in to debian with the pi/raspberry account
2.sudo su (switch to su mode without the root password)
3.ls /dev
(list all devices, depending on the type of drive)
Look for /dev/sda
Note your SD card will be listed as /dev/mmcblk0 (with partitions p1, p2, p3)
4.fdisk /dev/sda (obviously change this to match your HDD configuration)
5.p (print the partition table)
6.d <Enter> <number> (for each partition to delete them) (Note this will wipe your drive, do not proceed unless the attached USB HDD drive is an empty drive)
7.n <Enter> p <Enter> 1 <Enter> (Choose appropriate size for your main file area)
8.n <Enter> p <Enter> 2 <Enter> (make sure to have left yourself some swapspace)
9.You can set the boot flag if you want, but it isn’t needed since your booting from the SD card
10.mkfs.ext4 /dev/sda1 (format the first partition)
11.mkswap /dev/sda2 (format the swap space)
Now we need to prepare the installation onto this new drive ready to boot
1.mkdir /a (create a folder called a in the root, this is where we will build our new install)
2.mount /dev/sda1 /a (mount our new drive on /a)
3.apt-get update (update our package sources)
4.apt-get install debootstrap (install debootstrap)
5.debootstrap squeeze /a
http://192.168.1.11:3142/ftp.debian.org/debian/
(do a minimal build onto our folder)
I use apt-cacher-ng on another machine, use
http://ftp.debian.org/debian/
Once the packages have downloaded and installed we should have an extremely minimal debian install in /a
Let’s move across into this new environment and start to build it up to be able to operate on it’s own
Download the kernel file from
http://www.bootc.net/raspberrypi/linux- ... _armel.deb
(Note : You may find that the version has been updated since I wrote this note, please go to
http://www.bootc.net/raspberrypi/ to find the latest file name if needed)
1. wget
Copy the downloaded files, linux-image-3.2.18-rpi1+_5_armel.deb and linux-raspberrypi-3.1.9-18-arm.pkg.tar to your new area (/a/root/installation was where I put the files)
1.chroot /a (Change root to our new folder)
2.passwd <Enter> (follow instructions to set the new passwd for root on your new install)
3.apt-get update
4.apt-get install aptitude openssh-server locales ntp
5.dpkg-reconfigure locales
This should provide us with a remotely accessible platform once we get the kernel installed
Let’s get the kernel and modules installed
1.cd /root/installations
2.dpkg -i linux-image-3.2.18-rpi1+_5_armel.deb
The new kernel is now stored in /boot. In order to update your SD card to use this kernel you now need to do a little slight of hand
The file you need is in /boot called vmlinuz-3.2.18-rpi1+, and to use it we need to copy this file and rename it to kernel.img and store it on the SD card
When I applied the kernel update on my SD card, I did the following
1.mkdir /tempSD
2.mount /dev/mmcblk0p1 /tempSD
3.mv /tempSD/kernel.img /tempSD/kernel.img.original
4.cp /boot/vmlinuz-3.2.18-rpi1+ /tempSD/kernel.img
5.nano /tempSD/cmdline.txt
6.(modify the boot command by changing root=/dev/mmcblk0p2 to root=/dev/sda1)
7.CTRL+O,<Enter>,CTRL+X
8.umount /tempSD
9.rmdir /tempSD
These changes now mean you have the up to date kernel on the SD card and you’ve modified the boot commands to use your USB HDD as the root file system
Now do a reboot (reboot <Enter>) and let’s see what happens
The first thing you should notice is that it boots up fairly quickly. Always a good sign I think
The second is that you should be able to logon as root, using the password you set earlier
Now we need to make a few modifications to the configuration in order to automatically get the internet connection up and running
1.Log on to the PI
2.nano /etc/network/interfaces
3.Add the following lines to the file if they are not already present
auto eth0
iface eth0 inet dhcp
4.Before we forget, we need to turn on our swap if it hasn’t already
5.nano /etc/fstab
add the following line
none /dev/sda2 swap sw 0 0
6.exit
7.swapon /dev/sda2
8.To address a bug I keep finding with the network connection, edit the sysctl.conf file in /etc and include the line vm.min_free_kbytes=32768
9.Now you should be able to reboot and have networking available
