carlosqmcg
Need Help Changing Epiphany's Default Search Engine.
Sat Oct 25, 2014 6:06 am
I am totally new to the Linux environment, so I need step by step instructions on how to change the default search engine in Epiphany. This Duck Duck Go site is driving me crazy. Can anyone please help?
flynch
Re: Need Help Changing Epiphany's Default Search Engine.
Mon Nov 17, 2014 1:50 am
This was trickier than I expected.
Here are the steps to change the default search engine in epiphany on raspbian:
1. edit /usr/share/glib-2.0/schemas/org.gnome.epiphany.gschema.xml
This is an xml document. Around line 12 you will find the entries for the keyword-search-url. You will want to change the default tag for this key to point at your preferred search engine rather than duckduckgo. In my case I edited the file so that it looks like the following:
		<key type="s" name="keyword-search-url">
			<!--default>'https://duckduckgo.com/?q=%s&t=raspberrypi'</default-->
			<default>'https://www.google.com/#q=%s'</default>
			<summary>URL Search</summary>
Once applied this will cause epiphany to use google as its default search engine.
However editing the file does not apply the change. You will need to rebuild the schema cache to have this change take effect.
2. Before you can rebuild the schema cache you need to install the glib-compile-schemas binary. You can do that with the following command:
$ sudo apt-get install libglib2.0-bin
3. Now you can compile the schemas:
$ sudo glib-compile-schemas /usr/share/glib-2.0/schemas
4. Restart epiphany, google should now be your default search engine
Liberal Artist
Wed Dec 10, 2014 10:56 pm
This was really helpful, even for a reasonably experienced Linux user (very comfortable working at the command line and so on). I couldn't find any real documentation for how to do this, or much of anything on running Epiphany outside of GNOME. It seems like this would be a common task, so I'm surprised it's so involved and so scantily documented.
Mequa
Mon Feb 09, 2015 8:47 pm
I tried the above hack on Raspbian on my new Raspberry Pi 2 Model B.
Unfortunately it doesn't seem to work. While Web / Epiphany does indeed now load Google when attempting to search from the browser bar, it does not search for the query entered, but instead prompts for a new search from the Google website.
Is there a fix available for this? Allowing Google as default search engine would vastly improve the browser experience.
robwriter
Mon Feb 09, 2015 10:55 pm
+1 to trying to find a solution. I know there are lots of reasons why people would prefer not to use google, but not being able to do so feels weird!
zhihao
Tue Feb 10, 2015 2:50 pm
New here, how do you ¨edit /usr/share/glib-2.0/schemas/org.gnome.epiphany.gschema.xml¨?
It seems I cant change the permission of the XML file.
Thanks.
Mequa
How to change Web / Epiphany's default search engine
Tue Feb 10, 2015 3:38 pm
zhihao wrote:Hi,
Thanks.
Update: This fix now works on the new version of Web / Epiphany.
You can try it by opening a Terminal and typing:
sudo leafpad /usr/share/glib-2.0/schemas/org.gnome.epiphany.gschema.xml
Leafpad will print some garbage in the Terminal window, you can ignore this.
Or if you prefer to use a purely text-based editor in the Terminal, use this instead of the above:
sudo nano /usr/share/glib-2.0/schemas/org.gnome.epiphany.gschema.xml
Then use Leafpad or nano to change the following section (this is the whole section to change):
                  <default>'https://www.google.com/search?q=%s'</default>
                  <description>Search string for keywords entered in the URL bar.</description>
         </key>
Or for UK users, Google.co.uk is recommended instead as it saves having to access a server across the Atlantic.
Try this instead if you are in the UK:
                  <default>'https://www.google.co.uk/search?q=%s'</default>
         </key>
The text editor should then successfully overwrite the system file with root privileges. Save the file and exit the text editor.
You then need to install the following dependency from the Terminal, if it's not already installed:
And then recompile the browser schemas from the Terminal, as follows:
Close the Terminal and restart Web / Epiphany.
This fix works now, and this also shows how to edit the system files with root privileges.
Mequa
Wed Feb 11, 2015 7:14 am
OK, I found a fix. I've also updated the above to reflect this.
Update: The correct code to enter in the schemas file is:
         </key>
Update: This fix now works correctly.
If you are in the UK, you can replace google.com with google.co.uk in the above code (or use your local Google search if outside the US and UK), which should make it slightly faster, too.
zhihao
Wed Feb 11, 2015 2:53 pm
Thanks. At least changed from duck duck go which gives bad results.
casperc
Thu Feb 12, 2015 7:40 am
Mequa wrote: With this fix, Web / Epiphany will attempt to query the search term from Google.
It is somewhat slow though, as it will enter it into the Google homepage search, then bring up search suggestions, requiring pressing enter again (in my testing). At least it does search from Google now, though.
To fix this, use this instead:
         </key>
Mequa
Fri Feb 13, 2015 11:22 pm
         </key>
That fix worked perfectly. I changed the above from google.com to google.co.uk which also works fine.
It might be worth writing a script which does this automatically. It appears this difficulty arises running Web / Epiphany under LXDE rather than GNOME which has configuration tools for it. For now this manual method works fine using the above code.
Edit: I updated my guide to this in the above post here, so beginners can have a simple step-by-step guide to this which just works.
Scott Chiste
Tue Jul 14, 2015 7:47 pm
It is the step where i need to recompile that i am stuck.
I typed in exactlymwhat was asked, and ut says "Error on line 13 character 67: ' ' is not a valid character following a '<' character; it may not begin an element name . This entire file has been ignored."
What do i do from here :?:
DGxInfinitY
Tue Feb 02, 2016 3:27 am
I am also getting errors when I try to compile the schema file.
Gomoto
Sat Mar 19, 2016 1:38 pm
You can use dconf-editor to change Epiphany's default search engine.
First install dconf-editor in the terminal:
sudo apt-get install dconf-editor
Then you can change the default search engine with dconf-editor:
org/gnome/epiphany keyword-search-url
dev_bot
Mon Jun 06, 2016 4:20 pm
Thanks a lot for everyone's help and contribution on this! It really helped! :D
Also, it's worth using the command line method to open the file like this:
because if you try to edit it WITHOUT superuser, it will not work.
"Ooh, pie!"
