mariosangiorgio
Optimal memory split for an headless server
Sat Oct 18, 2014 7:31 am
I own a Raspberry PI model B with 512MB of RAM. I am not running any graphical application on it. It just run a few services and when I need to administer it I do that via SSH.
I see that my /boot/config.txt file contains the following line
gpu_mem_512=316
I am not using anything graphical at all so it feels a bit of a waste. At the moment my system is not memory hungry, but I don't foresee I'm going to attach a screen to it so I'd like to have a memory split optimised for my use.
What is the optimal split for my situation?
Re: Optimal memory split for an headless server
Sat Oct 18, 2014 7:45 am
If you're not using any of the intensive GPU functions, you can get away with gpu_mem=16 or gpu_mem_512=16
Check that it has worked (after a reboot) with vcgencmd get_mem gpu
mariosangiorgio
Sat Oct 18, 2014 8:01 am
Thanks, it worked. It rebooted, the setting applied and everything is running fine.
