B+ refuses to take "raspberry" password
Posted: Fri Oct 10, 2014 6:31 pm
by dan158
My new Raspberry PI B+ is refusing to take the "raspberry" password.
This is it's first boot up. I don't have an HDMI cable laying around so I tried to SSH to it.
RPi's address is 192.168.1.2 (however, when I tried 192.168.1.3 it made the green light at the Ethernet connection blink). This is after I've, once again, deleted my 'list of known hosts' from my Linux (Deb-Jessie) system to try and SSH into RPi again;
xxxx@xxxxx:~/Desktop$ ssh pi@192.168.1.1
ssh: connect to host 192.168.1.1 port 22: Connection refused
xxxx@xxxxx:~/Desktop$ ssh pi@192.168.1.3
ssh: connect to host 192.168.1.3 port 22: No route to host
xxxx@xxxxx:~/Desktop$ ssh pi@192.168.1.2
The authenticity of host '192.168.1.2 (192.168.1.2)' can't be established.
ECDSA key fingerprint is 9c:e6:12:98:22:1f:dc:9e:63:e0:e6:2b:ec:55:f5:18.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.2' (ECDSA) to the list of known hosts.
pi@192.168.1.2's password:
Permission denied, please try again.
I'm sure I'm missing something, wracking my few remaining gray cells to figure it out and getting nowhere.
Re: B+ refuses to take "raspberry" password
Posted: Fri Oct 10, 2014 7:23 pm
by elatllat
Firstly list open ssh ips on your network:
nmap -p 22 192.168.1.0/24
Secondly what OS did you put on there?
Posted: Fri Oct 10, 2014 7:38 pm
by dan158
Thank you for your responce
I haven't gotten to the stage of installing an OS. this was its very first boot.
nmap readout, (I haven't unplugged the Rpi yet).
:~$ nmap -p 22 192.168.1.0/24
Starting Nmap 6.47 ( http://nmap.org ) at 2014-10-10 13:33 MDT
Nmap scan report for 192.168.1.1
Host is up (0.00048s latency).
PORT   STATE  SERVICE
22/tcp closed ssh
Nmap scan report for 192.168.1.2
Host is up (0.00011s latency).
PORT   STATE SERVICE
22/tcp open  ssh
Nmap done: 256 IP addresses (2 hosts up) scanned in 3.01 seconds
Posted: Fri Oct 10, 2014 7:42 pm
by DougieLawson
What do you have on your SDCard?
If you're trying to install NOOBS without a keyboard/screen you'll need to do a "silentinstall".
http://raspberrypi.stackexchange.com/qu ... ut-display
Posted: Fri Oct 10, 2014 8:01 pm
by elatllat
dan158 wrote:...I haven't gotten to the stage of installing an OS. this was its very first boot.
SSH only works in an OS, and that's what you boot.
NOOBS is an OS of sorts but I would just skip it and to to raspbian.
Posted: Fri Oct 10, 2014 8:06 pm
by mahjongg
NOOBS is an Installer, not a fully fledged OS, although it might us a linux kernel, but that does NOT make it an OS.
Posted: Fri Oct 10, 2014 8:08 pm
by dan158
Thank you for the link DougieLawson. That looks promising. I'll try it and get back to you all.
I was sure I was missing something and that looks like it. :)
Posted: Sat Oct 11, 2014 2:52 am
by elatllat
Technically it is an "embedded Linux operating system".
http://en.wikipedia.org/wiki/Operating_system
It may be restrictive but it runs at least user 2 apps on some hardware, and really that's the only requirement for an OS.
