xtremegamer
Emulate Dev boards on Raspberry Pii
Fri Sep 26, 2014 9:45 am
Hi all,
I'm new ! :D so go easy on me :oops:
so what i'm questioning, is the raspberry Pi capable of 1.) "emulate" a teensy++ 2.) let the emulated teensy access gpio, usb, usb micro ?
I don't see any reasons , except that the 'teensy' would not be able to use the usb's.
please provide some insight , i'm kind of lost why this hasnt been done before :roll:
Thanks in advance,
Xtremegamer
ghans
Re: Emulate Dev boards on Raspberry Pii
Fri Sep 26, 2014 2:56 pm
First , the Pi has no analog inputs.
Second , people haven't managed to put the Pi into device mode with Linux in the first place.
Third , the data lines on the Micro-USB port of the Pi are unconnected. You can only use the port as power input (as designed).
ghans
xtremegamer
Sat Sep 27, 2014 7:17 pm
Thanks for the extensive response !
