Solarfreak
Apple keyboard does not produce correct chars
Sat Sep 20, 2014 11:32 pm
I am new to the RPi-World. I would like to use my RaspberryPi (Model B) with an Apple keyboard Model M2452 ( QWERTY - it came with a MAC G4) but it does not produce some characters such as '@' and the various brackets '[' , ']', '}' and '{'. I had set it up in the init-procedure to the 'Macintoh-option'. How can I set up the software (for use with Raspbian) such that I also get the important chars correctly? This is how the keyboard looks like:
> http://www.bing.com/images/search?q=app ... edIndex=23 <
I found in the internet:
> http://www.raspberry-pi.co.uk/2012/06/0 ... keyboards/ <
a list of Apple keyboard and that models A1048 and A1243 are compatible with the RPi. I hope that this does not mean, that my keyboard can not be made compatible.
Re: Apple keyboard does not produce correct chars
Sat Sep 20, 2014 11:56 pm
sudo raspi-config
You need to set your internationalisation options. The Raspberry Pi defaults to a UK keyboard and GMT/UTC as the timezone. If your keyboard isn't getting the right characters you need to set your alien characteristics using raspi-config.
Solarfreak
Sun Sep 28, 2014 11:56 am
I have done all this and I still can not produce the special brackets "[, ], {, }. I gave up at this point and got myself a HP-keyboard with all the special keys. From left to right:
Strg, a key with 3 curved lines, Alt, spacebar, Alt Gr, a key with 3 curved lines, a key with a document, another Strg-key. I chose keyboard option HP SK-250x (on the back of the HP keyboard it shows "Model SK-2502U").
Finally I found that with Alt Gr-8 I got '[' - Halleluja. However, I still do not know how I can work the raspi from my powerbook-keyboard.
When booting I observed a warning:
"kernel lacks cgroups or memory controller not available, not starting cgroups (warning)".
I can not imagine, that it has to do with the keyboard problem but it makes me nervous anyway.
I am using a 32 Gb SD_Card. but I get the same warning also with a preinstalled 8 Gb raspi-SD-Card.
WHILE I am at it. I can not 'shutdown'.
When I use 'sudo shutdown now' it goes through the shutdown procedures but reports at the end:
"root account is locked, starting shell" and I end up with what I believe is the 'root shell'
I have tried -P and other shutdown-options but my only option sofar is "to pull the plug".
klricks
Sun Sep 28, 2014 1:47 pm
In raspi-config, select one of the generic keyboards eg. 101. 104
More importantly you must properly complete the next menus and choose the country for keyboard. If in US you must choose: English (US).
When done you must reboot the RPi to apply changes.
Ignore the kernel lacks cgroups or..........
The proper shutdown syntax is:
reboot:
sudo shutdown -r now
halt:
sudo shutdown -h now
Solarfreak
Sun Sep 28, 2014 11:04 pm
thanks, now I can cleanly exit with 'sudo shutdown -h'. I really don't know, why it did not work before? Maybe I miss-typed or forgot the 'sudo'. Also the HP-keyboard is working correctly. Remains the problem of addressing my raspi via LAN from my MAC. Will study using RSS. Will I have the problem of having to install a second user because of the second (different) keyboard or can I easily swap between two different keyboards in one and the same user account?
Re the warning "cgroups not loading" will follow your advice - but in such a situation I do not feel comfortable, if I don't know what it means.
