MacsandaPi
Re: New releases of NOOBS & Raspbian
Tue Jan 13, 2015 7:56 pm
DougieLawson wrote:The version is "version of NOOBS" not the version of the installed OS.
The installed OS is "Raspbian Wheezy v7" as reported by cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
The kernel & firmware versions are reported by uname -r (or uname -a) and vcgencmd version commands.
This is helpful; thanks.
jamkirbs
Mon Jan 26, 2015 9:38 am
So that is the reason why it doesnt have the Raspbmc? So how can i install raspbmc? Where can i download it?
Mon Jan 26, 2015 9:46 am
jamkirbs wrote:So that is the reason why it doesnt have the Raspbmc? So how can i install raspbmc? Where can i download it?
If you have a internet connection via ethernet cable NOBS will offer to download/install other Operating Systems
or do not use NOBS http://www.raspbmc.com/download
Retired disgracefully.....
craigrodgers
Thu Feb 12, 2015 1:07 pm
Sorry if this has already been asked, or is a daft question, but im new to Raspberry Pi, and have a quick question.
I have bought the kit with a NOOBS SD card (which I think I may have accidentally wiped when I formatted it) I then re-downloaded NOOBS onto the card, put it into my PI, and booted it. I am only looking to use it for XBMC/KODI, so was looking to run "openlec" op system, it shows on the list, but doesn't seem to be on the card (if that makes sense), and when I select it, my screen just goes off.
Can anyone help or advise what I need to be doing, or where i'm going wrong?
RaTTuS
Thu Feb 12, 2015 1:50 pm
http://openelec.tv/get-openelec
^ get the image from there if you only want to use it as a media centre on that card use another card for raspbain ;)
Covfefe
craigrodgers
Thu Feb 12, 2015 5:42 pm
Thanks for that. I'm not sure which one im supposed to choose for my raspberry pi b+
Can you tell me which to go for?
Mequa
Fri Feb 13, 2015 10:47 am
RaTTuS wrote:http://openelec.tv/get-openelec
Having done a recent install with NOOBS (lite edition), I discovered there is now an updated OpenELEC for Raspberry Pi 2 available on NOOBS! Ready to download and install right from the Pi with a freshly flashed NOOBS image on the micro-SD. I successfully got it installed alongside Raspbian on a single 32GB micro-SD card on my RPi2. :D
There is also an updated OpenELEC for Raspberry Pi 1 available on NOOBS.
kevwil
Wed Feb 25, 2015 3:41 pm
The download (zip) link for the latest 1.4.0 version of NOOBS seems to be broken, I get a 404 error.
Wed Feb 25, 2015 7:26 pm
This is a doctor free zone.
SherlockPi
Sat Mar 07, 2015 10:03 am
A newbie to RasPi ! I have installed Raspbian on SD card. When I connect it to a HDMI display I can see the RasPi boot and stop at config screen. I am not having a USB keyboard as of now. I am trying to connect using SSH, I connect the RasPi to my laptop using ethernet cable but cannot see any IP assigned to RasPi when I do ifconfig. Is it required that at least once the RasPi should be booted normally and then we can use SSH? I am using RasPi 2.
Sat Mar 07, 2015 11:12 am
SherlockPi wrote:Hello,
http://www.raspberrypi.org/documentatio ... /README.md
SherlockPi
Sat Mar 07, 2015 1:00 pm
@fruitoftheloom
Thank you for the link! But I am not able to see the ip address generated for pi (when I do config) . During normal boot on screen I can see that the boot stops at the config screen (as this is first time boot) can ssh be used for first time boot itself ? (I have connected the pi to my laptop using Ethernet )
Sat Mar 07, 2015 1:06 pm
SherlockPi wrote:@fruitoftheloom
What has your question to do with the Original Post regards versions of Noobs & Raspbian etc :?:
Though this recent post may be more relevant to your issue http://www.raspberrypi.org/forums/viewt ... 3&t=103120
Last edited by fruitoftheloom on Sat Mar 07, 2015 1:09 pm, edited 1 time in total.
SherlockPi
Sat Mar 07, 2015 1:08 pm
I am using Raspbian and posted this in beginners section. Should the question go to a different forum?
SherlockPi
Sat Mar 07, 2015 1:10 pm
Oops it's just new release of Noobs and raspbian ! Got that will post in correct forum!
Sat Mar 07, 2015 1:12 pm
SherlockPi wrote:I am using Raspbian and posted this in beginners section. Should the question go to a different forum?
No you hijacked an existing thread ;)
Killertechno
Sat Mar 07, 2015 11:08 pm
Hi guys, I've seen there are updated OS images.
Where can I find changelog for various images?
I can't understand differences between Raspbian and Noobs...
Sat Mar 07, 2015 11:09 pm
Killertechno wrote:Hi guys, I've seen there are updated OS images.
https://github.com/raspberrypi/noobs
Rasilon
Wed Mar 25, 2015 7:05 pm
how did you install it alongside raspbian?
Wed Mar 25, 2015 7:17 pm
When you first boot the NOOBS installer / chooser with an active internet connection via ethernet, you will have a choice of not just Raspbian but other OSes, which is all covered in various guides such as:
http://www.raspberrypi.org/help/noobs-setup
Return to “Beginners”
