matthewtb
Kindle power supply
Sun Jun 17, 2012 5:58 pm
Hello my pi is coming soon and I want to get everything ready. I think I have a power supply but I am not sure: can I use a kindle USB with ac adapter. The adapter says it is 5v however the mA is 850. Is this okay to run my beloved pi on without blowing it? Thanks ( oh and by the way I am not the best when it comes to mA or voltage!)
dom
Re: Kindle power supply
Sun Jun 17, 2012 6:00 pm
Should be fine.
rgh
Sun Jun 17, 2012 6:09 pm
Mine runs from the Kindle charger without any problem.
Sun Jun 17, 2012 6:16 pm
As long as it is rated at 5v, and the mA rating is *at least* 700mA (higher is good), then it will be fine.
I have run my Pi from a Kindle charger without problems, although am using a 2000mA (2A) supply now, which also runs some other stuff.
davidmam
Sun Jun 17, 2012 7:17 pm
I found that the long Kindle cable dropped the voltage too much for reliable behaviour. You may want to try a shorter USB cable.
..d
matthewtb
Sun Jun 17, 2012 7:54 pm
Thanks guys
